Stargazer
Ok have bx-23 fel mmm BH 15 hrs total, Took BH off last fall to use rear blade. Finally thought to check tran/hyd level. Yikes nothing on stick dump 1 qt sudt did have and drove 10 min and then parked week. cleaned stick looked down fill hole can't see nothing. Dump 3/4 GAl SUDT and letting sit but still can't see level in hole and stick is dry. Ok I suspect some oil is in BH to keep stab arms out bucket support Yadda but a Gallon? out of less than 3 in whole unit. Yes I can keep dumping in till see but what happens when put BH on and cly raised pushing fluid into tractor. Yes trac is level FEL is down 3pt is down and no leaks other than 1/3 teaspoon on unconnected BH. ASS U ME ed full from fact/dealer check . Everything works/ed normally in use but pto doesn't gring going front both rear and 4wd selector works better.
Thanx
Thanx
