Help, which tractor is strongest?
   / Help, which tractor is strongest? #11
stanz said:
I should have mentioned that I will be building the FEL based on plans found on various websites. It doesn't matter what frame design they have, just looking for information on these tractors.
They all have bearings in the front axles, they all have cast iron front axles, they all have a history of FEL installations on the same family of tractors. I think they all have cast iron transmissions as well. They all have the same basic wheel/tires sizes.
I'd look at the clutch design on the gears drives to see which would take the most abuse from constant engagement. The one with the blower should not be in the equasion if you plan on using it for that, the time frame to change attachments could be huge. The case is actually a hydraulic drive not a hydro which is a plus for you to plug into to operate the loader. The problem is they don't hold back and you'd need to be sure the brakes work. Chances are the engines could be changed from chassis to chassis with little work as they all were using a simular bolt pattern at that time.
I did sell a few back years ago, they seemed to work ok but they were limited. I know they are still working today or they were last year and every now and then another one pops up. I will say they were over rated for what they could do although they did beat a shovel and wheel barrow.
   / Help, which tractor is strongest? #12
I laughed when I read the comments about the reality check on 10 hp. I had a friend who was trying to clear a city lot with a snapper 12 hp. I offered to bring my 13 hp Ford up there (we're both Chevy guys). He said not to waste my gas, but I told him I was coming anyway. It took me 3 hours to do what he had tried to do and failed at, and with a 13 hp Ford no less. The only reason I went to a larger tractor is simply time. The little Ford would do anything my John Deere would do, it just took more time and sometimes a little thought on the right way to do it. Plus I didn't tear up near as much stuff on the Ford as I did with the JD due to the excess HP.
David from jax
   / Help, which tractor is strongest? #13
I'll put my vote down for the WheelHorse. Its a strong design, the Unidrive rear axle is reputed to be one of the strongest. I have a loader on a 312, which is a similar machine. No problems so far.
I havent had experience with any of the others, except a Ford, which seemed to be falling apart.
Some do offer a FEL. I would be very hesitant to expect much work power from 10 - 11 HP.
My tractor is 12HP. If there is one thing that it doesnt lack its power.
   / Help, which tractor is strongest? #14
KentT said:
IMO,
it's the gears and axles on the rear that take the stress
from pushing into the pile.
Tell Me About It!
I've twisted the rear axle off in my Bolens 850 3 times while using the front blade.
Of course this all took place over a period of 41 years which hain't bad I suppose.
   / Help, which tractor is strongest? #15
Hi
I would go with a Simplicity SunStar( Also sold as an Agco Allis 1920H, Duetz Ultima 1920/1918H, MF 2918H, 2920H). These are a very well built and tough tractor. I have a Agco 1920H( In addition to a Deere 455) and the 1920H definately has the guts for pulling, not to mention the ablity to mount a loader on it as well. The loader for them are run off the Front PTO with a pump. You would need the diff Lock( avalible on all early Sunstars), Ag tires, and rear weights. But they are a tough cobination. I use my Agco 1920H, for blowing snow, and pushing heavy snow and she works perfectly. I know one guy has a Sunstar and he pulls gravity wagons around. Also moves his header wagon around, for the 25F flexhead for his combine. Tractor handles it with out problems. I would look at one of these beauties. Not to mention the 20hp in the 1920H is much more powerful for the loader then a 10hp.
If You need a Diesel, look at a Duetz 5215 that has 4WD( I belive) and is much heavier then the 1920. Has plenty of power for running a loader.
By the way the Sunstars were built from 1987 to 1997. The later Sunstars had the Kohler Commands while early ones had the Kohler Magnams. The early ones had diff Lock, but the later models( I think around 96,97) did not have the diff lock. I have been very surprised at how my Agco 1920H handles a 2 stage blower with out diff. Lock driving into deep snow banks. Today, The 455 Diesel does all my grass cutting, but my 1920H is set up for cutting on the side of the hills, plus it runs my leaf collection system in the fall and Blower in the winter. While I now have the 455, The 1920H still has a place and I won't give her up any time soon.
If you would like opnions on the 455 Diesel, I would be glad to tell you about them too.
Take Care Jason B
2016 John Deer 5075E (A60462)
2016 John Deer...
Spreader Attachment (A56859)
Spreader...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Informational Lot - Financing (A56438)
Informational Lot...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A60429)
2020 CATERPILLAR...
