Help With Leaking PTO Seal on John Deere 430
   / Help With Leaking PTO Seal on John Deere 430 #1
Suburban Plowboy
Veteran Member
FL
Kubota L3710
I have a 1992 John Deere 430. I bought it used. Works fine. I had a mechanic look at it before I bought it, and he said the only issue was a hydraulic oil leak around the rear PTO seal. He said the repair involved a cheap seal, and he seemed confident that I could do it myself. I need to fix it, because oil is staining my driveway.
Can anyone here point me in a direction where I can find info on the part I need and how to install it? I've been Googling pretty hard, and I can't find anything. A long time ago, I Googled, and a seal kit popped right up. I let it go, and now I can't locate it.
   / Help With Leaking PTO Seal on John Deere 430 #2
Go to jdparts and put your model no. in, parts will pop up.. here is a pic of the rear end Shows the gasket that you may want (key #9).
Or maybe the seal (key #19) which is part # M86229.
There is a repair kit AM39995 but I'd check with your Deere dealer to see what is in that kit.
Thanks for the help. Can you tell which way that group of parts is facing? I can't tell the rear from the front.
   / Help With Leaking PTO Seal on John Deere 430 #4
Look close for the "direction of travel" arrow.. almost cut it off when I cropped the image.
And think you should be able to use this link to jdparts to look up the same image.
https://partscatalog.deere.com/jdrc/
So "direction of travel" is Deerese for "front"! I was able to find the diagram, but I didn't know which way was which.
   / Help With Leaking PTO Seal on John Deere 430 #6
Yup, guess one has to assume that "direction of travel" is Forward.. and not reverse.. ;)
When will you launch into the tear-down? Take some pics and post your progress, as it will be good for the TBN archives..
I'm still not sure if I know what I need, and I don't know how to do the repair. Still looking around.
   / Help With Leaking PTO Seal on John Deere 430 #8
Is it a working tractor, that you use now to do weekly chores such as lawn mowing? If so, you likely don't want to venture into it blind..
But if being out of working order for up to couple weeks isn't a problem, then suggest you drain the tranny oil, take a pic or two, post it here and let your TBN members walk you through it. That is if you want to know by doing it. There will be bolts holding the cover (key #4) on, and seals to remove and replace along with the cover gasket (key #4). But doubt much more, and if you have a Deere dealer with a parts dept. available you won't have to wait long for parts (and Amazon is pretty handy too within a couple days or so). With posts and pics, think we can walk you through this..
It's a half-hour job for some, but know how you feel when it is the "first time" . Up to you to decide.. May help to get a dealer estimate in advance as incentive. ;)
I have to apologize. Today I had someone operate the hydraulics while I watched. The oil is leaking out of the rear of the hydraulic cylinder which is below and to the left of the seat. I could have sworn the mechanic said it was the PTO.
So...how do I get started? Should I try to find a service manual? I'm sure I can replace the seals on a hydraulic cylinder, provided nothing is marred, but I will need information to get the cylinder out and reinstall it.
Well, I found a manual online. The cylinder which is leaking is called a rockshaft cylinder. New term for me. The manual says to replace it if it leaks. I don't even know if that's possible for a 1992 tractor. Hard to believe it can't be repaired.
   / Help With Leaking PTO Seal on John Deere 430 #11
Available from Deere... AM116154
You can look these parts up too by going to jdparts.. see reply #4
I ordered a cylinder. I'm not too happy to see that they are made so you can't rebuild them easily. This thing cost $9200 over 25 years ago, so it's not unreasonable to expect real hydraulic cylinders.
I'm going to keep the old one and fiddle with it. Ordinarily, I have machine tools at my disposal, but I have not moved them from my old location yet. When they get here, I'm going to see if there are ways to avoid buying new cylinders in the future.
   / Help With Leaking PTO Seal on John Deere 430 #13
Well that is not good news. Like some one once said, "If man made it, man can repair it" So I would give it a try if it was mine.
Richard
It appears that the ends of the hydraulic cylinder are welded on, so in order to fix it, you would have to cut them off, fabricate new ones, thread them, and thread the cylinder body. It might be easier to modify a cylinder from Surplus Center.
The new cylinder is here. It looks like you just pull the old one, remove the fluid connector, install the new one, and screw the connector in.
Problem: how do I get fluid into the new cylinder? I'm sure it's full of air, and there is only one opening in it.
Well, I'm wrong. Looks like it has two. So I just hook it up and work it until the air goes out?
   / Help With Leaking PTO Seal on John Deere 430 #16
Yup, correct.
Thanks again.
I got the old cylinder disconnected from the pins that anchor it to the tractor, and I removed the rear oil fitting. Problem: the front oil fitting is very stubborn, and it's in a place where I can't get good leverage on it. I tried to remove the upper deck of the mower, but it appears that you have to remove two control levers and a bunch of other stuff. I am thinking John Deere must have had an easier plan of attack.
Does anyone here have a clue for me?
If I could get at the front end of the hydraulic hose, maybe I could detach it instead of the rear end (cylinder end).
Well, I found a video of a guy removing the fender deck from a 430. The fuel tank would still be in the way, but hopefully that will not be hard to move.
Man, what a nightmare this turned out to be. Removing the fender deck is supposed to be a 5-minute job. Took me more like 2 hours, not including research. When I got it off, and I moved the fuel tank out of the way, I had very poor access to the cylinder and hoses, but it was enough to make the job possible.
To get the deck off my 430, you have to remove the shift lever in the floor. The engineering is unbelievably stupid. The shift knob protrudes through a small hole too narrow for a wrench, and the hex on the lever is BELOW the deck. I had to turn it about a tenth of a turn at a time. The person who designed this must have been trying to get fired, because no one can be that dumb and still breathe. I feel like welding a T-handle to it. I slathered the nut and threads with anti-seize, and I left the lever finger-tight so I would be able to get it off next time.
The annoying seat switch (bypassed with a cable tie) has a huge connector on it, and you have to feed it through a tiny hole in the deck with one hand, while holding the deck up with the other. Otherwise, the switch wires tie the deck to the tractor.
A good engineer would have used a boat-type kill switch that attaches to a cord and bracelet. Before I killed the switch, I had to restart the tractor every time I got off to pick up a stick.
The taillight lamps have to be pulled out of their housings in order to remove the deck. Pushing them back in is nearly impossible. I greased them, and I still had to wrestle with each one for over 5 minutes. For $9200, Deere could have put disconnects in the wires, or they could have used sockets that screw in, like, oh, every major vehicle manufacturer.
I don't know why my lawnmower needs taillights anyway.
The deck and seat must weigh 60 pounds, and when you lift the assembly, you have zero leverage. Like lifting an ironing board with a fat child sitting on the far end. It's a wonder I managed it.
The new cylinder is in, however. Hope it lasts a while.
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2008 CATERPILLAR 277C SKID STEER (A60429)
2008 CATERPILLAR...
2018 Kia Forte Sedan (A59231)
2018 Kia Forte...
24in pin on excavator tooth bucket (A61306)
24in pin on...
