Help with non working gauges
   / Help with non working gauges #1
jeephound1
Tyler, Tx
2009 cub cadet ex3200
I'm new to the forum, so hope I get this correct.
I just purchased a 2009 Cub Cadet Yanmar EX3200 tractor and my fuel gauge and Temp gauge are dead. All warning lights, tach, hour meter, headlights and dash lights work perfect. Any help or ideas? Thank you
Thanks, I did check all fuses and they're good. Each gauge has 3 wires on back of them, red, black, yellow. With a test light bought gauges red wire has power.
   / Help with non working gauges #4
I'm sure you have probably checked the sensors making sure the wires are connected to them?
yes sir, even tried grounding the positive wire on the fuel sending unit. Nothing happened with the needle on the gauge. I haven't pulled the sending unit from the tank.
   / Help with non working gauges #6
Do you have a wiring diagram? I am wondering if one of the 3 wires going to the gauges is for illumination?
I bet the yellow one is lights, I'll check it.
   / Help with non working gauges #8
I would guess yellow is ground, black and red hot. Sure nuff a guess.
Fuel gauge worked a couple days off and on, but not the temp. Could it be a ground?
   / Help with non working gauges #10
Short answer, but yes it could be ground.
Lone Star dump trailer (A55973)
Lone Star dump...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
PREDATOR 8750 GAS POWERED GENERATOR (A58374)
PREDATOR 8750 GAS...
JOHNSON 6HP OUTBOARD MOTOR & STAND (A58374)
JOHNSON 6HP...
AEREATOR (A58214)
AEREATOR (A58214)
