Help with shear pin info
   / Help with shear pin info #1
houstonscott
Elite Member
Oglesby, Texas
Kubota L3800, Kubota GR2120, Kubota RTV1100, Kubota 5100sc
New here, broke a shear pin on a Howse 6' HD mower. It's just a steal bolt type of pin. Need to know what grade it is and how long. It appears to be 1/2" stuff. Can't find it anywhere. Help. Oh didn't run over anything I think I just engaged the PTO a little over idle and it broke or I may have throttled up a bit to fast and it broke.
HS
   / Help with shear pin info #2
I think most shearpins for brush hogs are Grade 2 and 1/2 X 3 1/2. Check your owners manual or call Howse to be sure. Ken Sweet
   / Help with shear pin info #3
I have run my Howse mower for years with grade 5 (3 marks) bolts as shear pins. I make sure the unthreaded shank portion of the bolt is long enough to go through the yoke.
   / Help with shear pin info #4
I have replaced shear bolts in my rough cut also only occasionally though and grade 2 bolts are tough to find and is what I believe is spec on them.
I have a grade 5 in mine and haven't replaced it since but I am careful when driving over saplings etc.
I have seen grade 2 bolts at the farm store you have to look to find a bolt with no markings thats a grade 2.
   / Help with shear pin info #5
I think the rule is like grade 2 for less than 40 hp and over that use a grade 5.
Great info, got to love TBN. The tractor has 57hp and maybe why I broke it so easy. Looks like I should buy half a dozen when I find them. Thanks..
HS
   / Help with shear pin info #7
With that kind of horsepower I recommend upgrading to a slip clutch. I think you have more torque from the tractor and a fair amount of centrifical force from the 6 cutter. I have a slip on the cutter but have had shear bolts on a few other implements and use grade 5 except for an old single bottom moldboard. It prefers the lower grade, although a punch is needed to get the broken softies out.
   / Help with shear pin info #9
HS
check your manual.. it's in there. my howse manual lists mine.. and howse manuals are downloadable.
IMHO.. I'd go grade 2 for gearbox and pto clutch safety.
soundguy
   / Help with shear pin info #10
Tractor Supply has grades 2, 5, 8.
larry
Service Truck (A59230)
New/Unused Mini Skid Steer Attachment Set A (A57454)
New/Unused Mini...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
