help with ym 135 hydraulic tap
   / help with ym 135 hydraulic tap #11
Not to dive to far off subject, what size finish mower are you running on your YM135 swedish fish? Providing I keep mine, I will be looking for a nice small finish mower for the 3pt hitch. Cheers Mike
   / help with ym 135 hydraulic tap #12
Hi Mike,
What you see in the picture is actually a Woods RM42 rotary cutter (bush hog). It's a good match size wise for this machine at 42". Not that it makes much difference, but my 155 is two more HP than the 135. Last year I did pick up a 3pt 48" landpride finish mower in hopes of consolidating to one tractor for mowing and light earth engaging work. (I also have a 25 yr old wheel horse). Due to the higher blade speed I think it cuts better than the wheel horse, but it is cumbersome mowing with the loader and the fact that the PTO engages with the transmission. For my situation, it's really not any faster and my neighbors giggle at me and think I'm obsessed with my tractor. Of course, they don't mind when I clear their driveway.
I heard you're moving to the suburbs. If it's any consolation, I live on an acre with about 1/3 of it wooded and I look for any reason to "have to keep" the tractor. I originally got it and a box blade to improve drainage and cut a swale preventing water from puddling against the house. Now we're talking patio. I guess I better keep it. :D
Sorry, don't mean to derail this thread. Green, I'd be very interested to see your loader. I'm impressed how tough these little tractors are. Just be careful of the front end. They're not as robust as the larger cousins like the 1500 or 1610 or 186. Still, for an acre of land I'm content.
Craig
   / help with ym 135 hydraulic tap #13
I do wish mine was a 4x4 model some days, but so far so good with carefull use of the diff lock. I am hoping to sell my 1965 JD 110rf w/mower deck and use the money to get a finish mower for the yanmar. I know of two Woods RM59's I can have my choice of for $250. I am used to the PTO kicking off when I put in the clutch, I mowed for several years with a Farmall Cub and a woods 42" finish mower. I already have the overrunning clutch on the rear pto. I also want to find a small moldboard plow to do garden work and plow at plowing events. Problem is most cat 1 plows are way to large for a 135. I wonder how many of these, the smallest of the green yanmars, are still out there. I dont see very many, mainly the larger models. Cheers Mike
   / help with ym 135 hydraulic tap #14
I am using a brinley 10" moldboard plow on my 1401D it works great. I took a sleeve hitch version and took the U shaped bracket off a sears sleeve hitch and welded a piece of flat stock across the back side with holes punched in it that allowed me to bolt it to the drawbar on my three point hitch. Then took a hitch stabilizer with a 2" reciever built into it and made the drawbar solid.
The system works like a champ will add pictures later today.
   / help with ym 135 hydraulic tap #15
I have less than $125.00 in the whole setup.
mbrule said:
Hi,
I too have a YM135. When I built my loader, I did as explained earlier, I removed the top of the junction block near the shifter and had a new one mide to splice into the line. I ran my return into a custom made cap with a quick connect that repaced the filler cap for the hydraulic fluid.
I can take some pictures if you guys are interested.
Matt
one question thou,did this affect your three pt hitch function?
   / help with ym 135 hydraulic tap #17
The only affect on the three point is that the loader and the three point cannot be in motion at the same time. My loader valve is a "power boyond" valve.
I am not a hydraulic expert by any means. I built a CadPlans loader and followed their advice how to connect it. I am pretty sure that when the loader is not in operation the high pressure fluid flows through the junction just as it did when it was only a junction block. Hope this helps!
Matt
swedish-fish said:
I'll try to help, but I'm sure there are others more knowledgeable than I. On my 155D there's a divider block in the high pressure line between the shifter and the steering column. I gather you can obtain a block that doesn't connect the two lines like the stock block does, but lets you essentially splice in line. I copied these from pages in my owners manual and service manual. Perhaps you can make sense of it.
I've never seen these blocks available. If you find a source, let me know. I'm sure it would be easy to make for someone handy on a mill.
ok so i attached my spool feed to the high pr out as seen in the pics,now the only way to get fluid to the spool is to move 3ph lever to raise then the the loader arms will raise.do i need a plug in the hp outlet to divert flow?and if so will 3ph work?size plug?
   / help with ym 135 hydraulic tap #19
Hi,
The second picture is exactly how i plumbed my loader. I removed the original "jumper block", which simply jumped those two ports together. I replaced it with a custom made block that routes each of the ports out, and plumbed my loader as shown. So effectively those two ports are again jumped, but through the loader valve, when the loader is not in motion. I do believe that you need a "power beyond" valve, as indicated by the picture (PBY).
I believe that be tapping in as the photo indicates, that your loader should be before the 3 point in the circuit, therefore the position of the 3 point valve should not affact the loader, but, the position of the loader valve affects the 3 point.
Hope this helps! I am certainly no hydraulic expert and can only lend my experiences.
Matt
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
