Help with ZTR for 6 acres
   / Help with ZTR for 6 acres #11
If it is more of a bumpy ride, I would take the time to take a test ride on a gravely ztr with the air ride, rubber mounted seat. I find it very impressive.
   / Help with ZTR for 6 acres #12
Check out Dixie Chopper. I cut around 4 acres a week and had mine for 4 years. I have had zero cost for maintenance other than changing oil and blades. Also they are very fast.
Sent from my iPhone using TractorByNet
I ended up with a Deere z930M 60" deck with the full suspension seat. I test drove many different ones and this was the most stable on the hills around the farm. I really like this new mower.
   / Help with ZTR for 6 acres #14
Good. I'm glad you found something to your liking.
I'm a fan of Z mowers. There's a reason the pros use them.
Best, Bill
   / Help with ZTR for 6 acres #15
Enjoy. I have the z465 60" residential type Deere mower. I now about 7actual acres of mostly flat and only some bumps. Its been great. I'm sure your 930 will be even better. You can never go wrong with a Deere.
iDrive TDS-2010H...
Kubota Snow plow with subframe
Kubota Snow plow...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60460)
2017 Peterbilt 567...
