3-Point Hitch Help,,
   / Help,, #11
On these tractors sits the hydraulic pump on the shaft for the the PTO. Therefore the PTO must be engaged and rotate to get oil pressure. Button on T-boom must be pressed simultaneously as one pushes the lever to 3 point hitch forward. On hitch there are three holes, the front one is hinging the middle is to lock the hook when no T-boom is in use and the latter is for the struts. check that there is nothing in the center hole. Remember that there is only a singel disc clutch on these so if it is pushed down then the hydraulic pump will not work
2014 Kubota M8560D (A53317)
2014 Kubota M8560D...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
John Deere 50 (A53317)
19088 (A55758)
19088 (A55758)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
iDrive TDS-2010H...
Cushman Cart (A55853)
