HF goods that are good (NON TOOLS)
   / HF goods that are good (NON TOOLS) #31
Nitrile gloves are good. Cheap disposable 1" brushes are handy to clean parts.
Does anybody know if their solar fence charger is any good? They are something like $49 on sale now, and I was thinking about getting one to keep a goat in the fence for my kid's 4-H project.
   / HF goods that are good (NON TOOLS) #32
Diesel fuel transfer....
I bought their little hand operated fuel pump. Similar to this http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95068 but it had a red fuel pump end. It worked very well the first time, but after that it stopped working as well and now I don't use it.
I thought about buying their battery operated pump (kerosene, so it should be OK for diesel). http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66203
I ended up buying this: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47334 (Jiggler pump). It worked surprisingly well. I pump my 5 gallon diesel container on the hood and siphon away. This is only the first time I used it, so I can't tell how it will turn out.
   / HF goods that are good (NON TOOLS) #33
OK, I know this is a "tools that are good thread", but...
I have the chain saw sharpener but have not yet used it, bought it this past fall but still use the files on an *** needed basis. I have 3 or 4 chains that need the sharpener though just waiting for some free time...
If you can find your receipt and you haven't opened it yet, you can still take it back. Their sharpener is a knockoff of the Northern Tool cheap sharpener, which is a knockoff of the Northern Tool $100 sharpener, which is a knockoff of the Oregon 511A sharpener.
I went through four of those cheap pieces of crud before I gave up. Too much plastic, too much vibration, too much wiggle equals no accuracy.
I just received the Northern Tool knockoff of the 511A. The fit and finish is not superb, but it only takes a few minutes to tune it up with a little sandpaper where the movement is rough. It is night and day difference from the HF tool, though, and works very well. One feature it has that the cheaper ones don't is the ability to tilt the chain 10 degrees (required for numerous chains). This is their $119 version, although it was just on sale for $85 in December. (oops).
Timewise, once everything is set up, I can sharpen a chain faster than by hand. However, sharpening by hand is still a little faster because you don't have to take the chain off the saw. The grinder takes off more meat from the tooth, but it is more accurate. My thoughts are that I'll use the grinder every 3rd sharpening or so, and file by hand (or with my Dremel tool attachment) in between.
2018 JOHN DEERE 317G SKID STEER (A51246)
2018 JOHN DEERE...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2017 Nissan Altima Sedan (A51694)
2017 Nissan Altima...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Adams 5 Ton HC Spreader (A53472)
Adams 5 Ton HC...
