Hi There from (way) Upstate New York
   / Hi There from (way) Upstate New York #11
Are you sure you want to install a BT600 on your X485? The BH probably weighs as much as or more than the tractor. I think you'll end up breaking the tractor.
Yes it's a little on the big side, but I'll be making a subframe to add support. It's been done before. Also, I'll be running a little lower pressure to keep the loads on the tractor down. We'll see how it all goes. If I don't like it, then the hoe goes back on craigslist and I'll rent a bigger one. The opportunity knocked and I jumped...
As for weight, the hoe is a bit under 600 lbs, the tractor with loader and some weights is more than twice that.
Matt
   / Hi There from (way) Upstate New York #13
:welcome: to TBN...enjoy.
   / Hi There from (way) Upstate New York #14
big project!
have you found a loader yet for the tractor?
   / Hi There from (way) Upstate New York #15
Hi Matt. Welcome to the forum. That sounds like a good project :)
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2018 HINO 338 KNUCKLE BOOM TRUCK (A51406)
2018 HINO 338...
2015 Chevy Cruze Sedan (A56859)
2015 Chevy Cruze...
Freighliner Tender Truck (A56435)
Freighliner Tender...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
