Hi There from (way) Upstate New York
   / Hi There from (way) Upstate New York #11
Are you sure you want to install a BT600 on your X485? The BH probably weighs as much as or more than the tractor. I think you'll end up breaking the tractor.
Yes it's a little on the big side, but I'll be making a subframe to add support. It's been done before. Also, I'll be running a little lower pressure to keep the loads on the tractor down. We'll see how it all goes. If I don't like it, then the hoe goes back on craigslist and I'll rent a bigger one. The opportunity knocked and I jumped...
As for weight, the hoe is a bit under 600 lbs, the tractor with loader and some weights is more than twice that.
Matt
   / Hi There from (way) Upstate New York #13
:welcome: to TBN...enjoy.
   / Hi There from (way) Upstate New York #14
big project!
have you found a loader yet for the tractor?
   / Hi There from (way) Upstate New York #15
Hi Matt. Welcome to the forum. That sounds like a good project :)
2013 Ford F-550 4x4 Auto Crane 4004EH 4,000lb. 2 Ton Crane Mechanics Truck (A55973)
2013 Ford F-550...
Willmar Wrangler 4500 (A56435)
Willmar Wrangler...
2023 Kubota SVL97-2 Compact Track Loader (A56435)
2023 Kubota...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
