High flow compressed air fittings versus standard flow..
   / High flow compressed air fittings versus standard flow..
5030
Did you ever check out the Prevost couplers?
Sure did and like about everything else, Amazon has them. Pretty expensive as well but I do like their proprietary push button disconnect and steel V style high flow plugs. Thanks for the heads up. When I think of Prevost, I always think of high dollar RV's and tour busses....lol
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
