High pressure "boost" pump
   / High pressure "boost" pump #11
Gasses are fluids. I think you mean liquids.
No, Gasses are (air nitrogen etc in gaseous state) Liquids such as hydraulic fluid or water dont compress for all intensive purpose.
Air compresses and when something lets go it is like a bomb it can really explode with shrapnel.
Fluid does not compress so when something starts to leak pressures drop fast, and no explosion.
M
   / High pressure "boost" pump #12
In physics, a fluid is a substance that continually deforms (flows) under an applied shear stress. Fluids are a subset of the phases of matter and include liquids, gases, plasmas and, to some extent, plastic solids.
that's a copy and paste.
Gasses are fluids, but gasses are not liquids.
IIRC from "high school", Liquids assume the shape of the vessel holding them to the level of fill.
Gasses FILL the vessel that contains them.
Both are fluids.
With that, a pinhole leak can send out a knife of a stream of liquid that will penetrate skin as easily as a razor.
Be careful, use hydraulic fittings and common sense. Typical automotive brake line systems run around 1000 psi. Not a good match for a 4ksi application, but better than plumbing fittings.
Oh! I hand pump my PCPs, it's good exercise and keeps me mindful of where and when I pull the trigger. ;-)
   / High pressure "boost" pump #13
M
Yah. Got that part.
Gasses store energy when compressed. Liquids don't compress so they pose less of a hazzard.
I guess I wasn't clear.
I was saying that gasses and liquids are both fluids.
You were using the word fluid, where (I think) you should have used the word liquid.
Liquid - Wikipedia, the free encyclopedia
..... On the other hand, as liquids and gases share the ability to flow, they are both called fluids......
   / High pressure "boost" pump #14
So you are using the 2.5" air cylinder to compress the high pressure while it is retracting right?
How are you holding the small tube to the cylinder?
   / High pressure "boost" pump #15
Both are fluids.
yes:
Fluid is ONE of the 4 standard observable states of matter State of matter - Wikipedia, the free encyclopedia others are listed above include Gasses, Solids and Plasmas. The reason I use FLUID is because the "term" most people equates as a "hydraulic fluid or Transmission Fluid." However liquid would be a technically correct term & most people think water when term "Liquid" is used. We are on a tractor site so use of "Fluid" for someone working in a garage making a high pressure pump is in my opinion adequate to get the point across. As for high pressure streams of fluid cutting YES they can and do cut thru steel all day long however again in the instance here he has very low volume of flow vs the pressure & ability to move the flow. To cut/damage the system need high pressure AND high flow to maintain the pressure. Cutting using High Heat and energized-pressurized gas (Plasma Cutting) is very popular as well.
Additional Physics info, GAS can be cooled and compressed to the point it condenses into its "fluid state" (such as propane) or they can precipitate out into it's fluid state (rain water from air/clouds.) A Solid material (1st state) can be heated until it changes into its 2nd state Fluid. It can be heated more to become Gas (3rd state) & continued heating with a charge it can become a PLASMA it's 4th common state. PLASMA is not a state that is easy to attain for most material and most Matter transforms into the 3 other states depending on pressure/temperature. Some will sublimate (transform from solid to gas) & bypass the liquid state such as Dry Ice changes from solid to CO2 gas bypassing the liquid state almost entirely.
M
The o-rings on the piston and at the bottom of the tube locate it OD/ID, pressure on the piston from the argon tank drives the HP piston up and the tube down. A "floating"system, it really is as simple as it looks.
That is also how it can get away with just air to the top of the LP cylinder.
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
