Highest lift on 3 pt hitch
   / Highest lift on 3 pt hitch #11
LD1 - can you explain your tip a little more - I think this is what happened to me with my blade but I am not sure - I put my new blade to good use and used top link to angle what i think is the A frame up to make the blade "scrape better" but what it appears I did was also scrape the heck out of my paved driveway :mad::mad:- especially on what appears to be where one edge of my blade was hitting the pavement when I had the blade angled. I have been thinking about this all day (my wife has not seen this yet :eek:and unless I figure this out I will be facing another year with a shovel) and I think you are hitting on what happened - the blade would in effect "dig in" at one end when angled because I did not keep the A frame level but tilted up quite a bit. Does that make sense?
Thank You Dana
In order to avoid this issue, I replaced the non-adjusting vertical lift rod on 3-point hitch with a short length of chain. This allows the implement to "float" rather than forcing one end of blade down. Made a world of difference for me.
Mike
   / Highest lift on 3 pt hitch #12
Mike
That is a great solution to the backblade "digging-in" problem. A pic would help see what you are referring to and help understand how you added the chain.
   / Highest lift on 3 pt hitch #13
Mike
Wow I never thought of that. I'll thik I'll have to give that a try.
Allthough there are times when I do want one side to dig more, but It wouldn't be hard to swap back.
   / Highest lift on 3 pt hitch #14
Mike
I can't do a photo anytime soon, but can offer a bit more description. Simply put, there are two mostly vertical arms that actually do the lifting - on most tractors, one had an adjustment capability(used to level an implement) and the other doesn't. I replaced the one that doesn't adjust with a length of 3/8 chain - with a shackle at both the top and bottom for connecting to the other 3-point components. Takes four minutes to replace with the standard rigid arm.
Cheers!
Mike
   / Highest lift on 3 pt hitch #15
You may also want to consider the draft load when deciding on which hole to use.
Here's the info from the 3520 manual:
OMLVU17926_J7
Click on the Using 3 Point Hitch link and scroll to the Positioning Center Link text and photos.
For light and medium draft loads: Install center link (A) in bottom hole (B) of mounting bracket. Example of light and medium draft load implements would include a landscape rake.
For medium and heavy draft loads: Install center link in middle hole (C) of mounting bracket. Example of medium and heavy draft load implements would include a tiller or box blade.
For very heavy draft loads: Install center link in top hole (D) of mounting bracket. Example of very heavy draft load implements would include a plow or ripper.
- Spindifferent
OMLVU17926_J7
- Spindifferent
Thanks! Great! I'll save it for future reference.
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
2012 Cottrell EZ-4807 22.5 Ton Car Hauler Trailer (A50323)
2012 Cottrell...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
CFG Industrial QK20R (A50121)
CFG Industrial...
