Hillside houses
   / Hillside houses #11
This summer I bought a house on the side of a hill - I viewed the property in May and moved in late July, always with the intention of relocating the house. The main reason I want to move it is that the house is too near the road but this past wet month (record breaking weather here in coastal BC with 30 consecutive days of rain) has exposed other reasons for moving it.
The land here is clay and once it became waterlogged, sheets of water began running down the hill unabated. There are some drainage ditches and curtain drains around the property but not enough - the attached photograph shows one location (there are others) where the rain forms a small stream running down the hill too close to the house. Since I took this shot, I've diverted the water temporarily but a permanent solution has to wait until the weather and ground conditions are more amenable to backhoe work. Much too soft just now.
When I move the house I'll place it on a plateau further up the hill where the terrain is much drier than the the current location. Further up the hill means, too, that there won't be as much accumulated cascading run off to cause problems.
The other reasons for moving the house are:
views of the ocean and islands opposite from further up the hill are better;
the house is too low on the east side of the hill so we lose the sun early. Moving it up the hill will extend the time we can benefit from afternoon and evening sunshine;
the house is only 100 feet from the road on an 11 acre property. When the house is relocated, privacy will be improved and the property will have more of an estate feel.
Houses on the side of hills are perfectly fine. As an architect, I've designed and sited quite a few on hillsides myself. Just be careful where on the side of the hill you site it and try to make sure that the location is good for all four seasons of the year. For solar exposure, south and west are best, north and east to be avoided.
   / Hillside houses #12
I have to ask. How do you plan on moving a whole house? especially uphill? Are you going to rebuild or actually move the current house. Sounds to me like a huge project not to mention expensive !!
Would that not hurt the structural integrity of the house?
If you are going to move the current house please post some pics. I would like to see how it is done.
   / Hillside houses #13
We have about a 150 yard driveway to the house off the road. "Gentle" slope to the house (once up a small 5 yard "'uphill" at the beginning of the driveway, you can put the car in neutral and "coast to the house").
Have a walkout basement, and the incline steepens at the beginning of the house.
On thing that I am grateful for is the fact the previous homeowner put in a french drainage ditch (almost like a curved L) about 20 yards before the house.
When we get heavy rains that ditch can "get going" with water, and takes that flow a good 40 yards past the house down the hill into a pasture.
We do get some water build up from heavy rains in some spots where there is a samll area that is almost level behind the house.
One of many projects is to drop some crushed rock and do a little landscaping in that area.
   / Hillside houses #14
Our current house has a walkout basement that serves as shop/utility/storage area. It is not suitable for any type of living accomadations unless serious modifications are made.
Our previous house also had a walkout basement that was very suitable for living and fully developed.
To me basements are dark uninviting living quarters, hard to access storage areas and junk collectors. The walkout feature negates these factors.
Not all sidehill terrain is stable enough to be suitable for building.
Present house showing basement entery and junk. /forums/images/graemlins/grin.gif
Egon. /forums/images/graemlins/grin.gif
   / Hillside houses #15
Picture from a little father away. Note: the street is 15 degree slope. The driveway is steeper in places. /forums/images/graemlins/grin.gif
Egon /forums/images/graemlins/grin.gif
   / Hillside houses #16
Our house is on the edge of a valley. The property is about 600 feet deep and the vertical drop from the street (house) level to the creek at the property line is 100 feet. The main floor of the house is at ground level but the slope enables us to have basement walkouts as well. This gives us three levels of comfortable living. The window you see on the lower level is in my workroom. /forums/images/graemlins/smile.gif
   / Hillside houses #17
The attached photo shows the walkout from the workroom. The large windows ont he left are in the family room. /forums/images/graemlins/smile.gif
   / Hillside houses #18
This photo shows the west side of the family room. The family room ahs five 4' x 6' widows which provides lots of light and makes it very comfortable. There is hot water radiant heating in the basement floor which makes it very it very cozy. Having a house on a hillside can be very enjoyable. One of the benefits we get fromt he lower level is a place to store equipment and wood.:)
   / Hillside houses #19
I'm planning a hillside house with a basement walkout also (it's sounding like a popular design!). I have already built the garage and in this picture, the future house will sit this side of the garage, and the riverfront is behind the camera. I hear that the septic system design may end up with a simpler system on a hillside too (simpler = less expensive!! /forums/images/graemlins/grin.gif)
   / Hillside houses #20
Check the local building codes for the acceptable location of the septic field before you decide where to locate your house. Local requirements may vary. As I understand our local situation, a new septic field must be installed above grade level and the base must be higher than the main floor level of the house. Also our local authorities require you to designate an alternate location for a septic field in case the first one fails. In my case, I had to agree to a provision to decommision one end of the driveway and use that area for an alternate septic field if the original failed, which it hasn't in 10 years. /forums/images/graemlins/smile.gif
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A55218)
2021 John Deere...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
