Historic winter storm ENZO
   / Historic winter storm ENZO #71
We are not out of the woods yet. The local weather man just said we have hit a record low temperature of 5* F this morning. The forecast was a low of 12*. The previous record was 9 set back in 1989. I remember that because we built our house the summer of 1989 and I could not keep the north bedroom warm for that event.
And, I woke up to no water this morning. I don't know if it's something frozen at my house, or if our rural water system is down. I expect I will have some broken pipes, even though I made lots of preparations for this.
I also filled several containers with water for brushing, flushing, coffee and cooking. I probably have about 100 gallons stored.
Way up here in Maine they say that every inch of foam over a buried pipe equals 12" of equivalent cover.
So if you're ever thinking about digging in your we'll or water line remember this.
I hope you guys are able to enjoy this snow event and the few pictures that have been posted say that's the case.
You have more snow on the ground than we do, although it was -14 this morning at 7:30!🤣
   / Historic winter storm ENZO #73
I am a short distance out of New Orleans. We didn't just break the record, we smashed it.
BEFORE
AFTER
Nine inches of snow is unbelievable here!
Everything is still shut down today.
I have to get my Kubota out to clear the driveway because my electric gate can't open.
   / Historic winter storm ENZO #74
Global Warming must have relocated?
...not in Alaska. It is a balmy 40 degrees F up there right now.
I got a message from a friend of mine in Australia where it was 110F yesterday.
   / Historic winter storm ENZO #76
To what other planet?
What Earth is doing:
What are the hottest years on record table?
Annual Global Temperature Records
  • 2024 Was the Warmest Year on Record. ...
  • Five Factors to Explain the Record Heat in 2023. ...
  • 2022 Tied for Fifth Warmest Year on Record. ...
  • 2021 Continued Earth's Warming Trend. ...
  • 2020 Tied for Warmest Year on Record. ...
  • 2019 Was the Second Warmest Year on Record......
per NASA
   / Historic winter storm ENZO #77
Some tips for those of you whose homes might not be built for this sort of cold. Most of these were shared to me by a plumber friend who really does not enjoy making emergency calls when it's -20˚F outside.
Make sure all hoses are disconnected from outside spigots. A hose left connected can hold water in the spigot and the bit of pipe running through the house wall. If it gets cold enough that pipe can burst when the water freezes and expands. (What many don't realize is that even an open hose can hold enough water in the spigot to become a problem.) At least in our northern climates, the actual shut-off mechanism on a good outdoor hose spigot is inside the wall (even though the knob is outside, and the pipe running through the wall is downsloped so that when shut off, the pipe drains out the spigot.
Open the cabinet doors under kitchen and bathroom sinks and any other water-using appliances on the outer walls of the house. You want the heat to circulate to any pipes under there. Unless your house is very well sealed and insulated, it can get substantially colder inside closed cabinets along outside walls. This is especially true on the upwind side of the home and in corners where two outside walls come together or where natural air circulation is poor.
Move couches, beds, pillows, etc. away from heaters. You want the air circulating unrestricted around them.
Keep heat circulating to any colder parts of the home where there are water pipes. If you find a cold spot, find a safe way to get heat to it. You may have to rotate space heaters to different areas of the home to keep things from freezing up.
Don't decide to save money by turning off or turning down your central heat and firing up your wood stove. If you have any way to keep your central heating system going, do so. The problem with turning it down is that your wood stove can keep your heating system from coming on. That may sound great until you realize that your woodstove on one end of the house is fooling the thermostat in the middle into not coming on. Now that baseboard heat on the far end does not have any circulation. Those water filled pipes are just an inch from an outside wall. Gaps in insulation can cause cold spots (especially corners where you may have just studs with little more effective insulation). Keep the water circulating in your heating system to keep a cold spot from freezing up. Once an are turns to slush, it will stop circulating.
Turn on faucets to check water flow. If it doesn't flow, get heat to it safely and soon. Some folks will leave a faucet dripping to help keep it from freezing up (interior faucets only!) If you do this, remember to check that your drain is functioning properly.
Know where your main water shut off is. (and hopefully any secondary shutoffs). If you hear a bang, your pipes have probably frozen. (A metal pipe sounds almost like a gun going off when it bursts. I have no idea what a plastic pipe sounds like.) Minimize damage by shutting things off as quickly as possible, so you don't continuously pour more water into the problem.
   / Historic winter storm ENZO #78
Last post. System I believe is gone and this is current snow depth. Enjoy
   / Historic winter storm ENZO #79
per NASA
Also seeing record low temps…
Some areas dryer and some wetter.
Friends that pioneered Washington State wine industry say every year the harvest improves…
When he was a new grad with plans to grow grapes conventional wisdom 50 years ago is Washington climate not suitable and he has proven the neigh sayers wrong.
With change often comes opportunity…
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
John Deere 6120E (A50323)
John Deere 6120E...
Simpson 3100 PSI Gas Pressure Washer (A51573)
Simpson 3100 PSI...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
JOHN DEERE Z530M LOT NUMBER 173 (A53084)
JOHN DEERE Z530M...
