OP
mark in portugal
Jumping ahead to 2019, when I did a bit refit. Bigger belt, smaller ratio to slow it down. bigger capacity hydraulic pump on the tractor to slow the engine down, and a totally new blade pack with opposed scissor action blades.
The rod bearings were shot; probably overstressed due to incorrect alignment. Since getting the pushrods right is really hard, I decided to switch to wobble bearings. That meant a whole new crankshaft.
New pulleys, wide belt, wobble bearings, and the holders I made for them.
I'll cut a section of this old rod to cut the crank from.
I have a saw now; it's shitty, but it's here and works.
Blank on the lathe;
It has to have a thinner web to make room for the new bearings, so instead of pressing pins into a disk, I cut it from solid.
Also, the wobble bearings will forgive the errors caused by my basic machining skills and machinery.
old and new.
Trying to get good lineup; it didn't come out as accurate as I'd hoped.
The hunt for center...
Blank on the lathe;
old and new.
