Homemade soil screener
   / Homemade soil screener
It's a nicely done video. It's a good how-to, but the video has nice editing and composition.
My guess is the bearing on the vibrating pulley has failed.
That was what I thought would go first as it was cheap and no grease nipples. But no it has held in and working fine. Thanks for comments.
   / Homemade soil screener #32
If that turnbuckle is for belt tension, it's also transmitting vibration to the rest of the device and in doing so its attachment points would be taking a beating. Perhaps it could be eliminated and the idler pulley used for tension, even another added to keep slap to a minimum. There must be enuf hp there to overcome a bit more friction in the drive train. Loosening that connection might also mean a lighter bob needed on the top pulley.
I'm imagining bent rod belt guides similar to those found under Craftsman mowers/decks if slap gets to be excessive.
Among my WAGs, it's conceivable that if steel belted tire rubber was used that metal within could fatigue and leave the rubber less able to hold the screen in position. These would be small refinements if needed at all.
The videos are among the best organized and edited I've seen in a long time. Way better than 30 sec of useful info/shots and five minutes of some guy hollering over the racket while explaining why he built something. IMO, just the right amount of seeing this well executed machine in action. "Two thumbs up!"
Very insightful comments old grind! Here's a photo of the three turnbuckles (belt tensioners) that have failed. This has been the only failure on the machine so far. The second photo shows a top link, that if it were small enough, would be the ideal replacement for the turnbuckles that I have been using. Two of the turnbuckles shown have been used extensively in other applications prior to being used on the screener so that might make a difference. The planes of the two turnbuckle mounting surfaces are not in alignment on my screener, so this puts a pretty hefty non-linear load on the turnbuckle. If everything were perfectly aligned the turnbuckle would be alternating between tension and compressive loads only. That would be bad enough with cheap turnbuckles I have used but with the misalignment we also get extra metal fatigue thrown in and that might explain the resulting breakages shown in the photo. When adjusted and tightened, the turnbuckle, vibrating pulley, bearing mount and screen frame are intended to be a "solid" unit that vibrates together.
No problems at all with the tire springs and tire hinges. I thought that the two springs might sag with time and usage so I built-in a provision to make an adjustment for this by making two in-line holes at the "bulge" of the springs through which a bolt and nut can bring in the bulge if needed. (I will post a graphic of this a bit later).
Think that doing away with the turnbuckle spring tensioner might be another approach that could be taken. But have to say that I'm more than happy (and a bit surprised) with the operation so far.
And - thanks very much for the kind words re my videos, really appreciate that.
A word re HP. The 6-1/2 HP engine cost me just $100 (on sale) and these are often available here. Also with the screen size in my screener, and when you dump a heavy load on at once, you really appreciate the available power. Of course this is especially true if the load is damp at all.
tractorgp; No problems at all with the tire springs and tire hinges. I thought that the two springs might sag with time and usage so I built-in a provision to make an adjustment for this by making two in-line holes at the "bulge" of the springs through which a bolt and nut can bring in the bulge if needed. (I will post a graphic of this a bit later). \[/QUOTE said:
As promised here's a graphic showing the holes made in the tire springs that are intended for a bolt and nut and washers. So far the springs have held up fine so no need for the adjustment feature to be used.
I just finished uploading the screener info with additional still photos and other information to the Instructables web site.
You can check it out here: Homemade soil screener/sifter
2019 Deere 550K (A53317)
2019 Deere 550K...
FORK ATTACHMENT FOR SKID STEER (A55745)
FORK ATTACHMENT...
2020 Nissan Altima Sedan (A55853)
2020 Nissan Altima...
2007 STERLING TRUCK L7500 CRANE TRUCK (A55745)
2007 STERLING...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
MINI DUMPER SDLD25 (A55745)
MINI DUMPER SDLD25...
