homemade wheel weights
   / homemade wheel weights #1
Hog86r
kubota l2800
i am the proud owner of a kubota L2800 HST with ag tires and FEL. some months ago i filled rear tires with water and it made a world of difference in traction. It occurred to me that a little more weight on the rear could reduce the need for engaging the front wheel assist and enable use of the FEL without a heavy implement on the rear.
Would an extra 150 pounds each on the rears be too much? the water added about 200 pounds each to the tires?
BTW, i swerved into an ingenious way to make wheel weights that are a perfect fit for the 24 inch wheels if anyone is interested.
thanks in advance for any opinions/advice.
good advice. thanks,
i am an avid fan of this site. however, i seldom have anything to add.
   / homemade wheel weights #6
I would love to hear about it.
   / homemade wheel weights #7
<snip> ... BTW, i swerved into an ingenious way to make wheel weights that are a perfect fit for the 24 inch wheels if anyone is interested.
Let's see 'em!
Here's your chance.
concerning the wheel weights:
someone will have to walk me through the process of posting photos, but i can give you a verbal description.
i bought a galvanized feed pan from tractor supply for $3.99 and melted some wheel weights (lead) and used the feed pan as a mold. poured the molten lead into the pan. it is the exact (almost) diameter as the inner part of the wheel. the wheel already has holes to facilitate mounting weights. so mounting should be no problem. my first casting i had to destroy the pan because the lead fused to the bottom. i have since learned a few tricks to prevent this from happening again. drilling the casting to access the wheel bolts and nuts is easily accomplished. just make certain to keep the drill bit lubricated or the lead will gall.
i await responses telling me it will not work. thanks,
   / homemade wheel weights #9
Why would anyone post that it would not work? Weight is weight.
I don't like pure lead myself because it's just too darned soft, but with some tin added, or even better tin and antimony, it's OK. Pure lead is dangerous to drill unless one breaks the web of the drill a bit to cut down the angle, otherwise, the drill wants to eat it's way into the lead, and with a large pioece, things can get ugly in a hurry...
Frankly, I think most folks would be better served with cast iron, but as with all things .. To each his own.
thanks for the information. i am guessing wheel weights like the kind the tire store puts on your car to balance the tires has the right alloy to make it rather hard. we used it for years for ballast on a race car. again, when we drill it just make sure to keep the bit lubed.
i dont have the facility to do cast iron.
thanks again,
   / homemade wheel weights #11
When I was a kid I worked in a lawnmower shop. A certain plumber used to bring in his tractor every spring and fall to have the wheel weights and snowblower put on or taken off. His wheel weights were cast lead and man were they heavy! :laughing: Easy to smash your fingers messing with that much weight - I know.
   / homemade wheel weights #12
...someone will have to walk me through the process of posting photos...
This link shows photos of how to post... or verbally done below... http://www.tractorbynet.com/forums/parts-repairs/157414-e14-electrical-problem.html#post1804853
When you post a reply to thread, After you type, below the text box is the submit and preview post buttons... scroll down more and you should see "Additional Options", the 2nd sub-menu is Attach Files where you have to click on "Manage Attachments". Once you click that, another menu box opens and you can browse for your photos. Just make sure they are not too big. Teg
   / homemade wheel weights #13
I just bet those pans would be heavy, plus trying to line up the bolts and put on the nuts. I will just have to keep the tiller on back of mine? I do have some wheel wt. lead , so might fill up a few ammo cans and stack them on back for extra 'heft" ?
   / homemade wheel weights #14
Speaking of wheel weights. Does anyone know where to go for second hand rear wheel weights for JD 5425? I prefer not to add fluid.
(18) 10'-6" PVC CONDUIT PIPES (A60432)
(18) 10'-6" PVC...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2003 International 4300 Cab and Chassis Truck (A55852)
2003 International...
Deere 310L (A53317)
Deere 310L (A53317)
John Deere 1025R (A53317)
John Deere 1025R...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
