Honda generator won't start.
   / Honda generator won't start. #41
whistlepig said:
I got over my mad spell and worked on the generator today. Pull starting a 13 HP motor that won't start really sucks. The spray mist bottle in the carb was an excellent suggestion. A pretty simple idea but something I would have never thought of. I picked a spray bottle up in town today and misted the carb with gas. Started on the first pull. It ran very rough unless the choke was left on. I drained all the gas from the tank and carb and replaced it with fresh gas. It ran like brand new after that. The gas I replaced was from this past February and it was treated with Stabil. It was brown looking when I drained it. Definitely going to have to rethink my long term gas storage situation.
Nice to hear and happy to see that you took it on first. Use high octane ethanol free gas and you will be fine. No additives for sure. Run it once in awhile and that will help. It's a great machine and will last years. Change the oil every 50 hours, that is cheap insurance.
   / Honda generator won't start. #42
Glad it worked for ya Whistlebuddy.......I've used to use a can of carb spray when troubleshooting small engine stuff but have graduated to the windex bottle.....at least it gives you a direction of the problem......
Sometimes you don't get off easy with it being just old gas but it doesn't hurt to check it first.......
One other thing, when my generator was new I added a tee in the gas line, on the drop I added a short piece of hose with a shut-off valve so I could drain the whole gas tank easily.......it'll dribble out slow but it will empty completely if the need arises again.....then I just add the old gas to my truck to get rid of it.....
   / Honda generator won't start. #43
I have a friend that puts manila tags with dates on his gas cans.......when he fills and stabilizes them he writes down the date.......when the date is 2 months old he pours it in his car/truck then refreshes his gas cans w/stabilizer
I'm thinking of doing the same......
The spray bottle idea was the best possible advice when I needed it the most. The spray bottle with gas will be a permanent addition to the "possibles" in my garage. And I agree as other TBN members suggested that I should run the generator more often. I'm not going a full year between fresh stored fuel anymore. Fresh fuel in the spring and fresh fuel in the fall. And if that doesn't work I'll let y'all know. Thanks for the help!
   / Honda generator won't start. #45
Just a word of caution. The generator head can also deteoriate from lack of use. Moisture builds up in the windings and causes a short. Just going to Stabil is a help, but you need to dry out those windings by running it with a load. From your comments you consider having a working generator very important, but your past maintenance does not show it. I used to encourage people to get a generator, however most people do not bother with the maintenance and they have wasted their money when it does not work in an outage. It is hard to think of running a generator every two weeks when two years go by without needing it. Run it often or sell it now while it still works. Sorry to be so obnoxious about this.
   / Honda generator won't start. #46
The spray bottle sounds like a decent idea but just remember to rotate the fuel in the spray bottle. or get a can of starting fluid. I sometimes use a little rubber bulb syringe to draw up some fresh fuel and squirt in the carb.
What I do with stored engines is first of all now I just treat all the fuel with stabil right in the storage cans when I buy it. So if I take a pressure washer or other piece of equipment to a job, when I bring it home it has the stabil in it already. Goes back in storage, when I take it out next time, if it's been several months, I dump that fuel and pour fresh fuel in the tank, before even trying to start it.
With a nice quality generator like yours, start it at least 3-4 times a year and dump the fuel twice a year. Also exercise the generator with an electric load, there are issues that could occur from not applying an electric load for long periods of time (will not produce AC power). An electric heater is a decent load to exercise with.
JB
   / Honda generator won't start. #47
JB
Also by using a heater you can see if it is actually working. You could start the engine every two weeks for a year and never know it's not actually putting out power. If you feel two weeks is too often, contact the manufacturer and see if they have other recommendations.
I also like to connect it to the house and run some house loads at least once a year. Most years this happens during power failures, but not always.
JB
I'm not much on starting fluid anymore. I have read too many bad things about starting fluid. I am kind of disappointed in the Stabil thing. This stuff was mixed to last a year and after 8 months it obviously failed. May not seem like a big deal to some but it's pretty serious business to me. Last power outage in February it was pitch dark in a ice storm with no heat and no water. Single digit wind chill. The generator just has to start in these conditions. And not with me playing with a spray bottle of gas with a flashlight. That's not an option.
   / Honda generator won't start. #49
First off glad you got the Honda fixed. I would love to have a Honda generator but man are they expensive. I bought a portable Honeywell 5500 watt generator from Costco 3 years ago. I believe it is made by Generac in China. Anyway about this time of the year I put fresh gasoline in the generator. As others have mentioned here I too drain the "old" gasoline and put it in my pickup truck. I've added Stabil gas treatment (red) in the past but this time I'm trying the bluish/green ethanol treatment Stabil. Got it at WalMart. One thing that I've done since I've had the generator from day one is to try to run it every weekend. I go out and it starts with one or two pulls. In the colder months it takes up to 6 or 7 pulls to start but it has never failed me. I know this is kind of **** and a pain sometimes but for the 15 minutes or so that I let it run, knock on wood it has started up. I'll probably jump to high test gasoline next time if not sooner maybe in the springtime. My 2 cents worth! Again, glad you got the Honda running, you have a great machine there. Stanley
Good advice! I doubt that I will run mine every weekend but I will for sure start it every month from now on. And I think high test gas is an option that I will be going to.
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
2021 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand...
2012 Terex RL4 S/A Towable Light Tower (A53421)
2012 Terex RL4 S/A...
