Honda GX620 won't run; no pulse for fuel pump
   / Honda GX620 won't run; no pulse for fuel pump #1
mcj115
Harrisburg pa
Deere 2305
I have a Honda GX620 engine that I can't get to get running at anything more than an idle after I force the fuel system to be primed. . The problem is fuel starvation....the pump isn't pulling fuel from the tank to the carb. The engine has a impulse driven pump which is driven by a line in the valley of the two cylinders. The problem is not the fuel pump...I have tried a few spare fuel pumps I have laying around all with the same result. I have tired hooking up a vacuum/pressure gauge to the port with no readings while the engine runs (at low idle).
Does anyone know how the pulse/impulse on a Honda Gx620 is created? There is a larger vent/breather line (maybe 5/8th) that runs from the intake horn right in front of the carb to the valley right above the flywheel; I did check this and when running this line seemed to have a pulse/impulse, but not the smaller 1/4 line to the fuel pump. From the looks there is some type of breather valve where the vent line enters the block. I am at a loss...could the breather value be bad causing a lack of vacuum preventing the impulse for the fuel pump?
Any recommendations/ideas are appreciated
Argh....I need to clock this one up to operator error! Sometime I don't think I should be left in the garage alone with tools.
Problem solved...I had the valve covers off. The crankcase could not; without the covers the crankcase wasn't sealed and couldn't generate a pressure differential. Popped the covers on and viola problem solved.
   / Honda GX620 won't run; no pulse for fuel pump #3
Slap yourself around a bit, then you will feel better, then have a cool beer.
2007 GMC Sierra 1500 Ext. Cab Pickup Truck (A46684)
2007 GMC Sierra...
42in. Skid Steer Forks (A46502)
42in. Skid Steer...
(3) Front Tractor Weights (A46502)
(3) Front Tractor...
Yale 50LX Cushion Tire Forklift (A45336)
Yale 50LX Cushion...
FLARE STACK (A47001)
2014 Chrysler 200 Limited Sedan (A46684)
2014 Chrysler 200...
