hooking up 3PH to attachment - is this normal or wrong?
   / hooking up 3PH to attachment - is this normal or wrong? #11
What you are seeing is normal. I wrestled with implements on my first tractor 6 years ago then bought a Pat's quick hitch system. Have since also bought a cheap set off ebay. Here are pictures of each set. The dollies sound/look like a great idea but I haven't done it yet but plan on it.
Thanks guys, I really wasn't sure if it was me or something was wrong.
That would be awesome if I could swap the pins - they are indeed pointing "out". But I bet they're welded in place or something? I'lll check that first though.
I like the idea of the quick hitch set up but will try the leveling and pins out first since I won't be using it that much.
   / hooking up 3PH to attachment - is this normal or wrong? #15
The last point (pun intended) is that hitching up the top hitch is a pain.... which is greatly reduced if you have a hydraulic top link AND can reach the hydraulic lever to adjust it while holding the top link in place. I made a PVC pipe device that fits over the hydraulic lever and reaches back out of the cab so I can shorten/lengthen top link and then fit the top pin in when it's just right.:D
   / hooking up 3PH to attachment - is this normal or wrong? #16
I second the PATS easy change system..MAKES a WORLD of difference, and the I added a hydraulic top link...now its a snap!!!:D
Excuse the fact I know nothing about this stuff - what uses are there for the hydraulic top link? I see where it could be very useful to adjust that independently of anything else.
Could I raise the MMM and then use the hydraulic top link to lower a brush hog, that way I wouldn't have to remove the MMM every time I brush hog?
Oh - actually I don't think I can on the B7100 - i think the PTO always spins.
   / hooking up 3PH to attachment - is this normal or wrong? #18
do a search on TBN for hydraulic top link.... the uses and experience has been widely discussed. let's just say that I consider it a mandatory attachment if you have more than one 3ph implement ... it also is totally wonderful for setting the angle of the rear implement... all from the SEAT:D
   / hooking up 3PH to attachment - is this normal or wrong? #19
I have a tractor with wide turf tires and I move some of pins to the inside and it works much better.
What also works for me it that I always do the left lower link first then the top link and then the right side lower link.
I wished twenty years ago when I got my first 'Bota that someone had written a "Tractor 3 point hitch for Dummies". You're lucky now...you have tractorbynet.com for help
Good luck.
Larry
   / hooking up 3PH to attachment - is this normal or wrong? #20
The basic use of a HTL is to be able to adjust the angle of attack for something like a box blade or rake or rear blade. You can adjust how aggressively the implement contacts the soil without leaving your seat. I do find it helpful for when I need to raise an implement a little higher to clear a rock or stone wall for example - just contract the HTL cylinder and up it goes.
They won't let you independently raise or lower your 3PH and MMM, but there is a way to do that on a BX and that is to rotate your mower height control knob to "TOP" which pins the deck up even when you lower the 3PH.
Here's a pic of my HTL
Edit: Oops I see you have a B so I'm not sure if you have the MMM control knob like the BX's
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
ALLISON TRANSMISSION (A55745)
ALLISON...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
