Snow Attachments Horst vs Woods Box Scraper for SNOW
   / Horst vs Woods Box Scraper for SNOW #11
Don't be concerned about it damaging the pavement. Box blades are created to dig. That's what will happen, you will peel off the blacktop like nothing. No reason to be concerned, because it will happen!
jb
While I have never used my BB on pavement I would think a simple adjustment of the toplink would prevent digging problems.
   / Horst vs Woods Box Scraper for SNOW #12
You are correct, IF (!) you adjust the top link for pulling forward, then adjust it for pushing backwards and NEVER forget to make the adjustment.
To keep from peeling off the asphault, you would have to tilt it nose high. A lot, so the back blade was holding the weight. But, in that configuration it will tear up the pavement if you go backwards. To push snow backwards, the rear has to be high and the nose low. But that configuration will dig going forward. When I move snow, the machine goes forwards and backwards a lot, there is just too much opportunity to look back and see a pile of "black snow".
Maybe if a set of extenders was added to the bottom sides of the box, that would raise the blades up and it could be done. But, for the amount of time, effort, money, etc, I would just buy a used 6-8' back blade and be done. Proper tool for the job and all that.
jb
   / Horst vs Woods Box Scraper for SNOW #13
I've used a box blade(72") around doors and entries at work with great success the last couple of seasons... one of them is a dead end about 40 ft that you'd use a blower on otherwise...
I couldn't be happier really--back up to where you want it, set it down and remove the snow... no windrows... does individual spaces great too if you get a doozy during higher traffic...
It isn't great for deeper than a foot (or less with the real heavy stuff), but for precision removal it's ideal.
thanks for posts,
we just picked up the tufline box scraper. the price was right. it's huge. similar to our front pusher. hopefully it will do the job. Our dealer says adjust link so it doesn't scrape like you said. we might put shoes on if it does start taking asphalt up. We will be taking the snow from one end of parking lot to the other. He said the snow will built up under the tractor and we will start sliding. so, we will have to lift up box and let some snow out or hopefully excess snow flows out over sides??
christine
   / Horst vs Woods Box Scraper for SNOW #15
Hi Christine,
Then you back up over the pile & push it ahead with the FEL.
I always end up with windrows at some point "down the road" when using the box on a large open area, because of the limited capacity of the box blade.
For open areas, the angled blade rules... for the tight spaces the box.
   / Horst vs Woods Box Scraper for SNOW #16
I have a Woods 5' blade it's endless what you can use it for. From grading roads to digging drain trenches to moving snow to spreading dirt.:)
   / Horst vs Woods Box Scraper for SNOW #17
Re: Horst vs Woods Rear Blade with Wings for SNOW
Wanting to buy Rear Blade with Wings for a L5030 kubota tractor for getting snow out of individual parking spots at a condo. Anybody try both snow blades? pros and cons of both?
thanks
christine and ray
For commercial snow removal...this is the machine for you...;)
Pronovost- PXPL Snowblowers
You can run right up to the parking stop and then hook the snow and blow it out as you leave the space...check out the video...:D
   / Horst vs Woods Box Scraper for SNOW #18
Christine and Ray,
A caution here....I pushed snow for 4 winters without a problem. On year 5, I pushed up against a frozen snow bank and bent one of my drag links. With an easy fix from 3RRL,
I see you still have the S M V sign on your BX.
I took those signs of both of my BX1500s cause i was always bumping my hands arms or elbows on them.
Don't need them on tractors that stay on my property anyway.
   / Horst vs Woods Box Scraper for SNOW #19
My driveway is located just as you start on a downslope and there is a lot of traffic on the road. I keep the sign on and generally turn all the lights I have on when I'm out near the road. In the winter, the plows push a lot of snow into the driveway, so it takes a fair amount of time cleaning the mouth of the driveway out...which puts me close to traffic. I try to be as visible as possible and I figure the sign helps. I upgraded to a 40 amp alternator this summer, so I won't be draining the battery this year when clearing snow for long periods with all the lights going. Dyer, retired
   / Horst vs Woods Box Scraper for SNOW #20
I left the brackets on the tractors and put the sighs up where they are handy if i need to take the tractor out on the road.
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
