Hot hose protection?
   / Hot hose protection? #21
Interesting old thread. Reading it makes me wonder if a restriction could be causing hot hydraulic oil. If so, it could be quick disconnects, backhoe lever/3pt connections, or a relief valve sticking. The theme that continues to pop up in some of these old threads is that the hydraulic quick couplers sometimes don't connect properly. Several people mention that they had to disconnect them, clean the tips, and connect them again.
This thread also contains a working link for simple hydraulic temperature gauge that fits some kubotas. From the context of the thread it may fit the B21.
Mostly what I read is a lot of good reports on the B21 from 20 years ago.
   / Hot hose protection? #22
Are the radiators clean enough to see light through them?
That reminds me that I need to open the hood and look at mine. I try to clean around in the engine compartment and radiators every year or so. A soft brush and hot soapy water followed by a garden hose rinse.
The Kubota doesn't leak oil so doesn' have a need to risk the damage that a pressure washer can inflict.
Next warm day,
rScotty
The oil cooler is an "open tube" design, basically a pipe bent into a bunch of "u-turns", nothing much to plug up.
Yeah, I think I will stick with either the HF infrared pistol, or the thermocouple plug in for my multimeter.
It is probably not "overheating" anyway, touching any surface that is over 120 F is likely to cause a reaction, especially if unexpected. I rarely smell the hydraulic fluid unless I am really pushing the machine in hot weather.
I will take more care with the QD's in any case.
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2015 WESTERN STAR  4900 SB (A55745)
2015 WESTERN STAR...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
