Hour Meter Test
   / Hour Meter Test #21
I look at it this way.
I just sold my NH 1320 with 620 hours after 14 years. I now have a TC26 with 60 hours in 3 weeks. At this rate I will have 4000 hrs or more when I finally sell this tractor and my resale value is out the window for the high hours I will have.
I would much rather have the tach hour meter than this new power on hour meter.
Peter
   / Hour Meter Test #22
I -do- change my oil filters at a higher interval during extreme conditions.. especially dusty conditions.
I didn't mean to imply 'idle' idle.. where the engine is cold nd there may be unburnt fuel getting to the oil.. etc.. but more of a high idle.. IE.. something to produce some usefull work... though not pto or tillage.. etc.
In any event... clock hour might give you an 'extended' change vs tach hours, based on work, if you were doing a hard, high rpm job.. etc. I'd rather change my oil sooner on those hard jobs.. vs later. I can't think of any lube related problems I've ever seen concerning shortened oil change intervals.. vs lengthened oil change intervals. We practice the same concept at the GC I work for... and the extra maintenance is probably a contribuiting reason why we have so many high hour machines that are nice and tight and still performing good. on the flip side.. I've rarely seen a rental machine that I would have wanted to own ( though not always specifically due to the hours issue )
How many here replace your diesel air filter more often than hours dictate, when in dusty conditions? I do...
Same with fuel filter.. Most people I know change them when 'needed'.. IE. when the machine breaks down due to fuel starvation... I like to change mine as part of regulatr maintenance... ( and prevent those fuel related starvation breakdowns.. etc.. )
Obviuosly everyone is going to have different ideas on maintenance. I was giving my opinion.. nothing more.. nothing less.
My opinion that an electric hour meter by itseld is not a great indicator of tractor usage... More preferably would be an electric hour meter AND a tach meter... best of both worlds.. etc..
Soundguy
RickB said:
You guys have too much time on your hands. How many of you change your car or truck's engine oil at a specific mileage interval regardless of driving style? What makes you think a tractor that has idled around at low RPM's and low operating temps doesn't need an oil change as bad or in reality worse than one that has had the snot run out of it for 100 hours? Change your oil at the recommended interval and be happy.
   / Hour Meter Test
RickB,
am not trying to get out of a oil change or any maint sch --infact I changed my air filter way ahead of sch-due to dusty cond, along with any other maint I feel is required.
I change my oil when needed...
I don't like if my key is in on position the clock starts running.
Two meters would be nice, my opinon any way.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
NEW 36'' Skid Steer Grapple Bucket (A53002)
NEW 36'' Skid...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A52748)
GOODYEAR SET OF...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
