How are the MMM with buildup?
   / How are the MMM with buildup? #1
Haywire
Central Kentucky
Tractorless :(
Got my 2660 in December, and am looking forward to spring and the grass cutting season. My old JD LT-180 required hosing out after every other cut (~2 acres each).
How do the Kubota decks fare when it comes to clippings building up under the deck?
Ian
   / How are the MMM with buildup? #2
I don't get any buildup to speak of. Maybe a quart scraped off when I change out the dull blades.
Depends on how wet the grass is, and what other type mowing you do - more than the deck IMO :)
If your previous deck required cleaning, then your new deck will likely require the same. ;)
   / How are the MMM with buildup? #3
Ian
Ian, Since you bought a belly mower YUCK!!!!!!!
Buy some "Mow Deck" spray to make the deck
non stick and just save your money and buy a
small rear mount flail mower from Ken Sweet.
   / How are the MMM with buildup? #4
I do not think any deck will be immune from buildup. Spray with vegtable oil, teflon spray, or add deck wash nozzels.
Washing mid mount deck in pond while attached to tractor is not advised as others have tried as the tractor sinks fast.
David Kb7uns
   / How are the MMM with buildup? #5
We didn't clean ours out at all this year nor did we spray it. There is minimal buildup.
   / How are the MMM with buildup? #6
Don't mow when it's wet? Seems to be the cure for any mower I've owned, mid, rear, or otherwise.
   / How are the MMM with buildup? #8
There is moisture in the grass even if you are careful to mow in dry conditions. I clean mine 2 to 3 times a season.
   / How are the MMM with buildup? #9
Leonz: I know you always push the flail mower. Which flail mower do you own?
I priced a 60" flail mower... Yeesh! Over $2K. Not this fellow. A tiller is much higher on the list and for less money.
2008 International 4400 Terex Hi-Ranger HRX-55 55ft Material Handling Insulated Forestry Bucket (A48081)
2008 International...
Wacker Neuson TH522 Telehandler (A50860)
Wacker Neuson...
2025 Unused Auto Darkening Welding Helmet (A49346)
2025 Unused Auto...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2014 Cushman Hauler 1200 Utility Cart (A49346)
2014 Cushman...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
