zonta223
Platinum Member
- Joined
- Aug 26, 2009
- Messages
- 507
- Location
- Adelaide South Australia
- Tractor
- Foton FT404, International 444 with forklift, International B250, Kubota L2000DT, Truck converted to all terrain forklift and lots of other junk
Also,to the guy who claims flyash is a better way to go....BALONEY! Flyash has been used AGAINST homeowners to STRETCH the mix(they may even cut the cement used when they add flyash)......nothing is a substitute for the proper amount of cement.
I'm sorry but this statement is wrong.
Flyash is not a "stretcher" or "filler"
I work in a concrete lab making and breaking concrete of all types and all different mixes.
Flyash mix concrete (with 15 to 20% flyash) after 56 days will be harder than standard concrete as long as the correct water cement ratio is used. It is also more resistant to attack by sulfates in the soil than standard concretes. Its heat of hydration is a lot lower than standard concrete mixes which is very important when you are pouring large slabs. Standard concrete generates so much heat when curing a large slab it may crack etc.
