How do i determine 3 point top link length i need?
   / How do i determine 3 point top link length i need? #1
DENALIAKITAS
Bought a tractor and it is missing the top link for the 3 point. I am wanting to pick one up but i am not sure how to determine the length i need. Thanks
   / How do i determine 3 point top link length i need? #2
What kind of tractor? Cat 1 or cat 2 hitch?
   / How do i determine 3 point top link length i need? #4
Probably either 20" or 24" body top link. I'm thinking 20 " will adjust 24 to 36".
   / How do i determine 3 point top link length i need? #6
Raise your hitch so that the draft arms are parallel with the ground. Now measure from the top link pin on the tractor out to where you are out as far as the pins on the draft arms. Have the tape measure parallel with the arms. This will get you what should be your true mid stroke length. Then go find a top link that is close to that measurement when it is at it's mid way adjustment. There should be an extended and retracted measurement available when you are shopping. Get one that matches your measurement when you figure the new top links mid adjustment length.
Good luck ;)
UNUSED FUTURE HL525 25" (A57193)
UNUSED FUTURE...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A55852)
2005 Toyota Tundra...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2011 International WorkStar 7400 Auto Crane Mechanics Truck (A55852)
2011 International...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
