How do I make a waterproof 120 V splice underground
   / How do I make a waterproof 120 V splice underground #21
I use a 1/2 conduit box like this one
Conduit Body, C, 3/4 In Hub, PVC - Conduit and Outlet Bodies - Conduit - Electrical : Grainger Industrial Supply
Put the wires in through the end holes, make the connections with wire nuts, then put a little tape on each end to keep the epoxy from running out. Fill the box with liquid epoxy and screw the top on. Costs less than $15 and it doesn't matter if the UF jacket has grooves in it. I've had trouble with the shrink connection type of splice, never had a problem with a splice embedded in epoxy.
Thanks for all your replies. I finally used the silicone tape over the compression chamber seal locks that were on the wires. I have had no problems so far. Ken Sweet
2014 GALYEAN 180 BBL STEEL VACUUM TANK TRAILER (A52472)
2014 GALYEAN 180...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51243)
UNUSED FUTURE BOX...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2021 Ram 1500 Bighorn (A52748)
2021 Ram 1500...
3 pt Finishing Mower (A50514)
3 pt Finishing...
John Deere 5225 (A50120)
John Deere 5225...
