How do i mix roundup??
   / How do i mix roundup?? #21
Actually, using too much can hurt. The tops die, but the plant recovers.
The trick is to mix the correct ratio and give it time to work. Too fast and you get to do it all over again.
Yes exactly right thats just what I learned from a landscaper and he was right you will think you haven't done anything and a couple weeks later its all dead for good. :thumbsup:
I use generic 41% glyophosate with surfactant rather than roundup but I still call it roundup. :D
   / How do i mix roundup?? #22
Just remember, the genes added to crops to give them resistance to Roundup are mobile and over time, will cross, and have crossed, to various weeds.
If you spray and nothing happens, either you forgot to add the chemicals, or you've got resistant weeds.
   / How do i mix roundup?? #23
What did they consider "too hot"?
One thing I have noticed new users doing is improper application i.e. drenching the plants. Some herbicides do require a thorough drenching, but in my experience Roundup does not.
I use Crossbow rather than Roundup as I'm spraying pasture and not looking to kill the grass. But to answer your question, I think I was using about 3-4 times the recommended concentrate per gallon of water.
   / How do i mix roundup?? #24
Thanks for the tip about using too much. I guess that can also happen if you over spray and an area gets sprayed twice. I have noticed about the tops turning brown and the plant living. I try to use dye...but it can be messy.
   / How do i mix roundup?? #25
Thanks, we use Roundup in some places and Crossbow in others, We have established some native grasses and use the Crossbow there where it works really well.
   / How do i mix roundup?? #26
Be careful!!I sprayed, the edge of my pond,later, found one of my grass carp DEAD!!!!
   / How do i mix roundup?? #27
   / How do i mix roundup?? #29
To read the directions on the container is the best advice. RoundUp comes in so many variations and even that may or may not change when crossing country borders.
198367 (A51243)
198367 (A51243)
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
2003 Hyundai Elantra Sedan (A55853)
2003 Hyundai...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2012 Jeep Liberty SUV (A53424)
2012 Jeep Liberty...
