How do I replace rotary cutter blades?
   / How do I replace rotary cutter blades? #1
jduke
I have a 72" Mohawk cutter on a 55HP tractor. I was mowing with it, and found a root ball that didn't give....One of the blades broke off at the bolt holes and then proceeded to violently shake the shredder for a couple of seconds before I could get it shut down.
Anyway, once I order a new set of blades, what's the procedure for replacing them? Is this something I do through the hole in the deck? Can I do it with hand tools or do I need an impact wrench? Guessing no other damage was done but who knows.
   / How do I replace rotary cutter blades? #2
You should be able to get to the nut through the hole in the deck. These are big nuts. 1 3/4" nuts if I remember correctly. May differ on your cutter. I use an impact wrench cause I have one it's easier. A big ratchet or breaker bar with a cheater bar would work also. These nuts are tight.
   / How do I replace rotary cutter blades? #3
Not certain about this model of cutters, but many require a new lock nut be used. Shims are also used to get the correct clearance between the bolt head and blade.
Yeah, ill order new nuts/bolts. Thats what the manual says. How do you keep the bolt from spinning? Or will it?
   / How do I replace rotary cutter blades? #5
On all the cutters I have changed the blades the shank of the bolt is keyed into the stump jumper. If yours is the same the bolt shouldn't spin. You may have to take a big hammer and punch to drive the bolt out of the stump jumper through the hole in the top of the cutter. This is usually a press fit.
Cool. Sucks. JUST had these things sharpened a couple months ago when the tractor was in the shop for a grapple install. :/ Its got a slip clutch too, not sure why it broke.
   / How do I replace rotary cutter blades? #7
The bolt is keyed on mine, but still a good two person job. I use a 3/4" drive, 4' long breaker bar to change ours, but you can use a pipe for leverage too. Get everything nice and clean for re-install, and consider some loctite on the new bolts.
   / How do I replace rotary cutter blades? #8
It's not easy but I have changed many blades by myself. It's easier if the one end of the rotary is lifted with a loader.
   / How do I replace rotary cutter blades? #9
I hook the chain hoist to the rear of the mower to secure it. The 5/8" thick blades on our mower are unwieldy but the keyed bolt usually does provide enough friction to hold the blade as it hangs there.
   / How do I replace rotary cutter blades? #10
I just changed blades & bolts on my older Howse 6' (about 20+ years old) cutter this past season. Our local farmer's co-op keeps bolts in stock and the ones for mine fit quite a few other brands as well. The nuts took a 1 11/16" socket - not quite in everyone's toolbox. The bolts on mine have a shoulder for a 1/2" thick blade and the keyed shoulder that fits into the stump jumper is ever so slightly tapered. The last time I had changed blades & bolts was about 15 years ago but the nuts came loose with my Snap-On 1/2" drive impact after soaking overnite with Thrust penetrating fluid. My deck has the typical hole behind the gearbox for accessing the nuts.
Hose Reel (A55787)
Hose Reel (A55787)
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
Brush cutter (A55973)
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
