How do I stop blowing oil seals?
   / How do I stop blowing oil seals?
Some of the tree limb cutters use what looks like large saw blades.
Our current blade is made out of some hard, 1/2" x 3" steel.
We do have a 29-1/2" steel saw blade (Probably came out of some old time saw mill) which we currently have on a stump saw we are trying to build. We have been wondering how it might work. I suppose the teeth are about 1" to 1-1/2" spacing and the weight would probably heavier. What would you think?
   / How do I stop blowing oil seals? #42
Another question. Our present gear motor has check valves so it can be reversible. Since we rerouted the return line, we gave up the reverse option. Might it be possible to remove one check valve to make a case drain?
This should work. You'll have to plug the internal passage that connects to the large return port though. Maybe tap it and jam a setscrew in the threads. The case drain will have to be a seperate low pressure line to the tank.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
RING 2 STARTS HERE @ 9:15 AM (A54756)
RING 2 STARTS HERE...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
