rambler
Veteran Member
- Joined
- Jul 6, 2003
- Messages
- 1,996
- Location
- MN
- Tractor
- Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
Re: How do you adjust a hydraulic valve? *DELETED*
</font><font color="blue" class="small">( This is what Junk said in an earlier post:
<font color="blue"> This is how the valve is plumbed into the system. I disconnect the hoses going to the loader valve and put these in between the loader hoses.... </font> )</font>
Which is still a little grey to me.
If he is disconnecting the regular loader disconnects, & adding in his grapple connects on _that_ side of the tractor hyd controls, then he is getting _zero_ pressure to the grapple from the tractor pump. All the pressure is supplied by the weight of the loader. The grapple would be piggy-backed onto the loader, and only works by shuffling oil from one side of the loader cylinders to the other - by the pressure of gravity on the bucket.
Now, if this 'Tee' plugs in somewhere between the tractor pump output and the loader valves - then it is real confusing that a closed center valve can work at all on an open center circut. I understand it does work - how is the mistery. An open center system would supply close to zero pressure to a closed center control - they are not compatable.
An out is that some control valves are easily convertable from one style to the other with the right parts inside a plug, and this would be the obvious answer - the grapple maker supplies a controller that will work on either OC or CC with the right plugs/parts.
--->Paul
--->Paul
