How do you adjust a hydraulic valve?
   / How do you adjust a hydraulic valve? #141
Re: How do you adjust a hydraulic valve? *DELETED*
Junk,
I know this is much later and I haven't read all the posts, but I am curious as to your connection of the gauge to measure the pressure. You said:
"...is registered at the end of the hose coming off the valve when the valve is operated."
The question is, did you plug that hose with the gauge, or did you Tee the gauge into the hose after the valve? If you plugged the hose with the gauge, you are stopping the flow, and the pressure you will see is probably a pressure relief setting somewhere upstream in the system. Normally when you want to know the pressure flowing in a system, you Tee into the line to connect the pressure relief valve.
To Madref:
I too have an electronic background, and I agree with others that there is something wrong here with our understanding of this system. Think of an open center valve as a near zero resistance path, a wire. If you parallel that with a 1meg ohm resistor, you aren't going to develop an voltage (pressure) accross your resistor. The problem is that you have a short circuit path through your open center valve.
I think the best working theory so far is that the grapple is actually operating with mechanical advantage from the open center no load pressure of a couple hundred psi, which might be enough.
Sorry if this seems to add more heat than light to the question, but I do find it interesting, and yes it is an engineering thing to want to understand.
</font><font color="blue" class="small">( Junk,
Sorry if this seems to add more heat than light to the question, but I do find it interesting, and yes it is an engineering thing to want to understand. )</font>
Yes, the gauge is a "plug" at the end of the line. I will try to do a tee reading in the spring when it gets warmer.
Sorry, but you can't add any more heat to the debate than has already been generated. I like everyone else want to get to the bottom of this... Junk...
   / How do you adjust a hydraulic valve? #143
<font color="blue"> Here is a better example. Connect your green garden hose to the spigot. Connect a tee to the other end and connect 2 hoses, one white and one blue, to the tee. Leave the white hose open. Connect a pistol grip on/off spray nozzle to the blue hose. Turn the spigot on.
</font>
When I do this I only get a little tinkle out of the blue hose. /forums/images/graemlins/confused.gif Is this what's running Junkman's grapple?
WOODS 9021 BATWING MOWER (A52707)
WOODS 9021 BATWING...
T/A Flatbed Trailer (A59231)
T/A Flatbed...
Towable Diesel Generator (A59228)
Towable Diesel...
Informational Lot - Financing (A56436)
Informational Lot...
ENCLOSED DRIVING SIMULATOR TRAILER (A58214)
ENCLOSED DRIVING...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
