How do you bend Titanium sheet metal?
   / How do you bend Titanium sheet metal? #1
Kyle_in_Tex
Super Star Member
East Central, Texas
JD 4310,JD5420
I made my wife a cookie sheet out of some Ti6Al4v (grade 5) that I had laying around for years. I think it is about .035" thick. I put it on the brake we have at work and started bending. I wanted about a 1/2" lip on the long edge for strength and a place to grab with a pot holder. When it got close to 90 degrees, it started cracking and in a couple places, actually split in half. I ended up tig welding it back together at the bend.
Pretty expensive cookie sheet I know. But the most expensive part was sanding it down to a decent surface finish. I'd say it has a 16 finish or so.
Probably should've engraved my name and the date on it so when my children's children's children use it, they'll remember my name. LOL.
   / How do you bend Titanium sheet metal? #2
I've always heard that it needed to be hot formed. Try heating it then putting it in the brake.
Does anyone know how hot?
   / How do you bend Titanium sheet metal? #4
I once toured a shop that did it. They had it red hot and then let it cool in the die so it wouldn't move. A quick Google search said 1200F.
   / How do you bend Titanium sheet metal? #5
You do know that titanium will burn if heated hot enough in air, right?
Can be a very difficult fire to extinguish in a hurry.
The powder is especially "sparky", so be careful with any grinding or sawing.
http://titanium.com/wp-content/uploads/2010/10/Material-Safety-Data-Sheet.pdf
Some forming & general info:
Warm forming titanium parts - TheFabricator.com
Some more info:
Forming of the Titanium and Titanium Alloys: Part One :: Total Materia Article
I love the material - I have been wearing a fairly inexpensive titanium watch for the past 6 or 7 years that has a titanium case, back and wrist band. It's eerily light and has held up well to the abuse I've dished out to it.
   / How do you bend Titanium sheet metal? #6
Kyle,
having over 20 years experience in precision sheet metal, I would say that you are trying to bend it to sharp. Measure the thickness with a micrometer. Then use a forming die that has an INSIDE radius that is 3 times that thickness. Also, being it will be a baking sheet, I would not bend it more than 60 degrees. As you get close to 90 degrees, the stress on the OUTSIDE radius of the bend is VERY high. When I would be working with Titanium, I would do what is called a "Soft form" to get 90 degrees, NEVER a "Hard form" as the metal COULD fracture along the outside radius.
For the finish, I would use a dual action orbital sander with 120 grit pads, then go to 180 grit or 220 grit. After getting it very even finish with that, go to a 400 grit, then to 800 grit. Take your time and be patient with the finish. After using the 800 grit, I would TRY making a pad of 4-0 (0000 that is) of steel wool. Wash very well with mild soap and water, and dry. HOWEVER, Titanium SHOULD have a VERY smooth surface to start with. If your sheet DOES NOT, it probably is an inferior grade. What I have worked with was always labeled as "T-3". :2cents: Best of luck.
Dave
   / How do you bend Titanium sheet metal? #8
So much for my idea of turning titanium sheet metal into a nice set of armored plate.
Kyle,
Dave
I think the larger radius is the secret for us backyard benders. The heat would be difficult to do in a small time operation.
What you really want is a suit of beryllium armor with kevlar undersuit.
200722 (A51247)
200722 (A51247)
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
