How Do You Fill Your Diesel Tank
   / How Do You Fill Your Diesel Tank #11
One of the prerequisites in designing is that you sign a disclaimer stating that you will never use what you've designed. Personally, I tend to eliminate some of the safety devices.
There is a saying
Which is as wise as it is witty
That a camel is a horse
That was designed by a committee.
I curse mine every time it leaks fuel all over the side of my tractor.
   / How Do You Fill Your Diesel Tank #13
We gave up and got gravity feed tanks on our farms; much easier and safer than climbing up on the tractor with 5 gallon cans.
   / How Do You Fill Your Diesel Tank #14
I gave up and got a 55 gallon plastic drum with a hand pump. When I got more equipment with bigger tanks, I bought one of the 240 gallon plastic totes and an electric pump. That's big enough that I can get home delivery. :thumbsup:
5 gallon totes are okay for the smaller equipment but now I have equipment with 20 and 28 gallon tanks.
   / How Do You Fill Your Diesel Tank #15
I have the 5 gallon flip off the saftey, then push and hold the lever kind of can (Blitz, next to last re-design:confused2:) But I am getting along OK with it.. Here is what I do, I have a old soft towel, that I use to put down on the hood after blowing the loose dust off. then I lift the can to the hood. (metal hood) with the can lying on its side (the valve does not leak) and the nozzle pointing at the filler neck on the tractor. Flip off the safety, and hold the lever, for about 5 minutes as it glug,glugs out. You do have to turn the can backwards to get the last of the fuel out but by that time most of the fuel has run out, and the can does not weigh much. Are these cans great? No. but I am doing OK with it and with my method, there is not much strain. Holding down the lever is easy, and you are not holding any weight.
James K0UA
   / How Do You Fill Your Diesel Tank #16
I had a bunch of these new CARB diesel cans. My 'ventless' cans developed leaks high up in the handles [ must have dropped something on them ] and I had to buy five of these 'poly vent utility jug' things from Amazon. Cost less than $13 for the five including shipping, which is a lot of buckazoids for little plastic stuff. But at least now, I have the holes plugged so stuff can't get in the can. Unless, of course, I happen to snag the vent cap on something whilst I am dispensing diesel, the little vent opens, and air gets into the can. The diesel flows out so much faster that I can quickly [ relatively ] snap the Utility Jug Vent back in place quickly after I am done. These are also sold on Ebay, but for about $5 USD each.... from a company in Kalifornia..... go figure....... :)
[ame=http://www.amazon.com/Scribner-Engineering-Spacesaver-Utility-Jug/dp/B000WJH62E/ref=sr_1_1?ie=UTF8&qid=1338290687&sr=8-1]Amazon.com: Scribner Engineering Spacesaver Utility Jug - Poly Vent Replacement 5223: Automotive[/ame]
   / How Do You Fill Your Diesel Tank #17
Back before all the govt. mandated hard-to-use fuel containers came into being - I was using 5 gallon plastic fuel jugs like the race car guys use. I bought two yellow ones for diesel - and I had a few red ones for gasoline. The two yellow ones I've had for eight years now as fuel containers for the BX23. They hold 5 gallons, have a large mouth (probably about a 3 inch opening) -so they are easy to fill. And they are square so and will stand up in the back of the truck without falling over on most corners.
I just bought two more because I'm getting a B3200 shortly and it has a larger tank (and will use more fuel).
Speedway Motors still carries them - I believe the Co. that makes the jugs is Scribner(s)?
I've had one of these jugs for something like 20 years for gasoline - still works just great.
Plus they're nowhere near as expensive as the newfangled cans.
   / How Do You Fill Your Diesel Tank #18
I bought a cheap battery pump on amazon. works well. for 12.00.
   / How Do You Fill Your Diesel Tank #19
When I'm feeling too lazy to fill the tank with a can, I make a road trip to the gas station.
   / How Do You Fill Your Diesel Tank #20
I struggled with a decent solution for this. Didn't want to keep lots of fuel on hand or wrestle a big tank around. Last year I ran across a Sierra Tools Battery Operated Transfer Pump. They are currently available from Amazon.com for $11.99. It uses 2 D batteries. I set my 5 gal cans on an old towel on the hood of my L5240HSTC. It empties the can in about 3 minutes. I've pumped 80 gals on the original batteries. The thing is one of my best ever finds. Last week I bought two more of them for another application and one as a gift for a friend with a CUT.
2023 Top Hat Industries Cool Down Trailer (A52377)
2023 Top Hat...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55218)
NEW 2025 Load...
