Oil & Fuel How do you fuel your TC30?
   / How do you fuel your TC30? #21
When I had my 1720 (essentially same as TC-30) which had a similar hood design, I use to open the hood most times. That way your 5 gallon fuel container could be held lower, and I don't think I ever spilled. In the rare case there was some minor spillage, it went down the little drain hose, but I can't honestly ever remember having any. Also, with the hood open, I could rest the gas can on a part of the engine, (maybe it was the air cleaner or power steering reservoir) and not have to hold the entire weight.
   / How do you fuel your TC30? #22
</font><font color="blue" class="small">( Since I have a diesel pickup as well, I bought a standalone 275 gallon oil tank from the local heating supply company, and installed a 110V AC diesel pump with a standard fuel nozzle (similar to what they have at a gas station) ordered online from Northern Tool. No more mess, and no more hefting a jerry can. Getting bulk fuel delivered is cheaper as well, not including the tax break because it's a business expense.
I do wish I'd spent a couple more dollars for an auto-shutoff nozzle and a flow meter. )</font>
********** I do wish I'd spent a couple more dollars for an auto-shutoff nozzle and a flow meter. >>
Can't you still add that now.?
   / How do you fuel your TC30? #23
Well sure I can... but then I'd have to toss the nozzle I have, wouldn't I? That's a waste of money, and I'm far too Scottish. If I'd just ordered the fancy-schancy thing to begin with... there's no turning back for us stubborn Scotties... you wanna buy it? Five bucks+shipping and its yours, nitwit.
I can put the flow meter on... but the tank has a float valve on it...so I can see if its got anything in it, and thats all I care about.
Frankly the point is moot... wife just accepted a very tasty relocation offer and we're selling the whole farm and moving to Pa... going down this weekend to scout out a new home for Bad Dog Stables...
Woohoo - I get to start again with a clean slate!
Well, I finally made it out to look at some of the suggestions for fueling without making a mess. The Handy Pump that is sold at TSC looks interesting, but I'm not sure the hose is long enough.
However, seeing as how the tank on the TC30 only holds 7 gallons, what I think I will do is go with a large funnel and three 2 gallon gas cans. With such a small amount in each can, approx. 20 lbs, it should be rather easy to hold and ring the funnel while fueling. I came about this idea while browsing around W-Mart after striking out at TSC.
   / How do you fuel your TC30? #25
I have 100% faith in the same cans that Derek has. I have 2 of them and have never spilled a drop of fuel while filling my TC30. The CARB cans were my solution to the same problem that you have. I had doubts at first on the plastic construction but since my dealer sells them I figured it can't hurt. When the tank is full the valve will stop the flow and you can turn them upside down and never lose any fuel.
   / How do you fuel your TC30? #26
Like I said, I've already replaced the hose on my Han-D-Pump. What I do with my 24 is set the 5 gallon jug on the running board of the tractor and then stick the nozzle in the fuel tank. It is plenty long enough for that. You won't want to sit the tank on the ground as then you'll have to bend down to pump it. If you do find that it is too short (I highly doubt that it is), You could just replace the entire hose w/ longer 3/8" fuel line. I would rather have that then have to worry about filling 3 cans each time I go to the station as that is 3X the chance of fuel to leak in the back of the truck/car.
   / How do you fuel your TC30? #28
No, I have never had to use anything other than just the cans. Just open the fuel tank cap and align the neck of the can. Set the tab of the neck on the edge of the tractor fuel tank and push downward. The fuel flows until the tank is full or untill the can is empty and lift it out. It's that simple.
   / How do you fuel your TC30? #29
</font><font color="blue" class="small">( No, I have never had to use anything other than just the cans. Just open the fuel tank cap and align the neck of the can. Set the tab of the neck on the edge of the tractor fuel tank and push downward. The fuel flows until the tank is full or untill the can is empty and lift it out. It's that simple. )</font>
Don't you filter your fuel before putting it in your tractor?
   / How do you fuel your TC30? #30
No, Always use fresh fuel and stick to the service schedule religiously (fuel, air, hyd. etc. filters). I have had a few tractors in my day and never had a water or dirt problem.
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
New/Unused 6ft Quick Attach Brush Cutter (A57454)
New/Unused 6ft...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
