How do you heat your barn/shop?
   / How do you heat your barn/shop? #41
The cost of running the heat through the floor for me was about $250 for 1/2" pex, 1500' of line
Taco pump, $100
Mixer valve, $200
12 valve log manifold, $100
My wood boiler heats my house and hot water too, so I dont count that in the cost to heat my barn
   / How do you heat your barn/shop? #42
I don't know if it has been suggested but you can often find cheap wood stoves on craigslist. There are also some on ebay, but that is hit or miss.
   / How do you heat your barn/shop? #43
I friend gave me his old wood/coal furnace for my 30X40X14 insulated garage. It does a great job heating to the point I work out there in a T-shirt,
   / How do you heat your barn/shop? #44
I heat a 70 by 30 shop in the cold northeast with an old oil fired forced air furnace. Only turn it on when I'm working and 50 degrees is fine for me. Doesn't burn much.
An aside...
I don't burn enough oil for an annual fill up so here's my twist. The 275 gallon tank that feeds the furnace also has a hand crank pump on it. I fill my tractor and dozer from the same tank. It's so convenient, and don't need to discuss whether or not to run my machines on heating oil -- it's the same stuff. The tank is outside so if the fuel was going to gel, it would gel in the filter or line to the furnace. The furnace draws from lower down in the tank than the pumps does, so the machine fuel is as clean or cleaner. Never had any problems with either. No additives.
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
20X 8 SHIPPING CONTAINER (A52472)
20X 8 SHIPPING...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
