how do you remove this?
   / how do you remove this? #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all i have an ariens 932 snow thrower with a 7 hp techumseh motor.
the motors dead, i want to replace it but i cannot get the main drive pully (sheave) off. i have taken the pins out (two) and the square key, i have wd'ed and it still will not budge. is there a "trick" to it?
thank you for your help.
Forgeblast
   / how do you remove this? #2
Probably need a pulley puller. Thing with three claws that fit under the pulley and a threaded rod in the middle that presses on the shaft. You tighten the rod with a wrench and the pulley pops off, rather loudly too.
   / how do you remove this? #3
Apply heat, lots of it. That will often do the trick. Worst case, you will need the puller AND heat. :)
Wear eye protection when using the puller. I had an India made Harbor Freight puller turn into a grenade. I ended up buying an expensive US made puller.
thats for the info reguarding HF's puller. where can you find better pullers. autopart stores? or HD or Lowes? Thanks again i appreciate it.
Forgeblast
   / how do you remove this? #5
I know Checker Auto around here will rent you a puller for cheap. Your local parts store may do the same. I think I paid $5 for a day to rent a puller to take my motorcycle engine apart.
   / how do you remove this? #6
If you have an autozone nearby AutoZone.com - Get in the Zone! they still have (I'm 99% certain) a tool rental program. Here's how it works: you buy the pulley puller from them and, when you're done, return it for a credit. Seriously. This is the way that their program works.
Richard
   / how do you remove this? #7
Richard
A full credit???
At Checker you buy the tool and then get most of the money back when you return it. It still ends up costing you a little bit.
   / how do you remove this? #8
Iplayfarmer said:
A full credit???
AutoZone gives you full credit on return, but I think their intent is to loan you tools to use when installing parts purchased from them. I don't know how they'd feel about just lending a tool. If you buy from them often, they might go for it. Can't hurt to ask.
   / how do you remove this? #9
I use the loaner tool program at Autozone quite a bit. It works just as described- you pay up front the full price for the tool, and you get all your money back when you return it- even the sales tax. So when you return it, it costs you nothing. They have a good selection of specialized tools.
-Fordlords-
   / how do you remove this? #10
-Fordlords-
That's it! I've got to find an Autozone!
I may have to drive a bit.
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A51242)
2006 CATERPILLAR...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52128)
2014 Dodge Ram...
2024 Polaris Ranger 1500 (A50514)
2024 Polaris...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
