How do you remove turn signal switch on Boomers?
   / How do you remove turn signal switch on Boomers? #1
bnixon
Houston, Texas
TC33D / 7308 ldr 60" HD bucket
I am trying to remove the turn signal switch on my TC33D from the black plastic panel and need to know how the switch comes off. I assume that the switch handle (for lack of a better name) just pops off and a retaining nut is under it. But it doesn't seem to want to pop off? /forums/images/graemlins/confused.gif
Can anyone tell me how this comes off?
Thanks,
   / How do you remove turn signal switch on Boomers? #2
Re: Need help from someone with Class II Assembly Man.
Brandon, I think your switch is very likely similar to the Class III switch, so I'll tell you how it is assembled. On top of the switch, there is a decal with a large left-right (<-- -->) arrow. That decal extends over the center of the switch. If you lift the decal at the center of the switch, there is a phillips head screw holding the handle onto the switch shaft. It's very much like the bail on a hose bib. You remove the center screw and the handle can be lifted off the shaft. On my tractor, the decal covers the hole, but I can see the round impression where the screw is located. I hope your part is similar and this helps.
Thanks Jinman,
Yes, this is the same switch on all of the Boomers.
   / How do you remove turn signal switch on Boomers? #4
</font><font color="blue" class="small">( Thanks Jinman,
)</font>
/forums/images/graemlins/frown.gifNot all Boomers. Mine only has hazards, no turn signals.
   / How do you remove turn signal switch on Boomers? #5
my 33d doesn't have turn signals (2001). WHy on a tractor anyway??????????
   / How do you remove turn signal switch on Boomers? #6
</font><font color="blue" class="small">( my 33d doesn't have turn signals (2001). WHy on a tractor anyway?????????? )</font>
When your tractor has been around for 50 years and someone is rebuilding it as a antique, they can say, "Hey! Look at this switch. It's just like new; looks like it's never been used." /forums/images/graemlins/shocked.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
   / How do you remove turn signal switch on Boomers? #7
because the laws in ohio and california require them. So it is easier to put them on all tractor instead of just tractors going to these states
   / How do you remove turn signal switch on Boomers? #8
</font><font color="blue" class="small">( </font><font color="blueclass=small">( my 33d doesn't have turn signals (2001). WHy on a tractor anyway?????????? )</font>
Ok, so where are these turn signals I've never seen?
)</font>
   / How do you remove turn signal switch on Boomers? #9
</font><font color="blue" class="small">( Ok, so where are these turn signals I've never seen? )</font>
Right there... in the attachment.
   / How do you remove turn signal switch on Boomers? #10
Thanks Jinman! (no I'm not SO stupid, my tractor is stored 5 miles away and I've had NO seat time this year due to the wet conditions. Mine is for my business use only. So I get no "play" or orientation time. And can't walk out to look. /forums/images/graemlins/smile.gif
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A55745)
2013 ORTEQ ENERGY...
2019 BOBCAT T590 SKID STEER (A52706)
2019 BOBCAT T590...
BFH 1000 BALANCE FORCE HARMONICS TIRE BALANCER (A54757)
BFH 1000 BALANCE...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2016 Ford Focus Sedan (A53424)
2016 Ford Focus...
2023 BOBCAT T62 COMPACT SKID STEER TRACK LOADER (A55218)
2023 BOBCAT T62...
