How does this bearing work???
/ How does this bearing work??? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Im in the middle of restoring a model 225 JD offset disc. I have it completely disassembled, sandblasted, painted. I have new discs. I have ordered new bearings. In examining the old bearings, I notice that it has a seal on either side that protct the balls inside. I also notice that the bearing has to be pressed into the bearing house ( I had to have a machine shop remove the old ones) which has a grease zirk in it. Originally, I assumed putting grease into the zirk greased the ball bearings in the bearing itself. After close examination, I cannot see how the bearings get greased because it appears ther there is no way the grease can get into the ball bearings themselves. Can anyone enlighten me.
/ How does this bearing work??? #2
i would think it might be used to keep the bearing cool when in operation
/ How does this bearing work??? #3
PLEASE tell me you did not paint the bearing hub bores or I will get another Schlitz out of the fridge!!!!!!!!!
If you did that you will have sand all the paint off, UGH!
Your new bearings are sealed with grease in them, which is also known as lubed for life.
do not worry about that part, and do not remove the seals or I will smack your patties:laughing::thumbsup:
first things first:
The press fit bearings will require you to put them in the freezer overnight to get them to drop in with a block of wood and a dead blow rubber mallet.
no worries about the bearings themselves :)
/ How does this bearing work??? #4
many bearings (originally) were only sealed on one side...new (improved) productions of the same bearing(s) now come sealed on both sides
Thanks guys. Luckily, I had a professional do the blasting and painting and they did not paint the bearing hub bores.
That freezer idea sounds good. I will definately give it a try.
So really, If I get bearings that are sealed on both sides, is there any need to put grease in the zirk?? I cant see where the grease has anywhere to go!!
/ How does this bearing work??? #6
There is a grove in some bearings that allow grease to flow to the inside.
Some bearings are double sealed, and some have seals one side only. The open side goes to the inside of the tube that has a grease fittings. Some people over grease bearings, and there is something called over greasing. To much is not good.
A good many of the pressed in bearings are not re-greasable.
Grease is inserted into the cavity where the grease fitting is, and the grease is forced into the bearing.
/ How does this bearing work??? #7
No need to grease it if it is sealed on both sides, if you did grease it could or would distort the housing and break it from the pressure if the press fit is still true which it most likely is.
I have had bearing surfaces so tight that the grease physically broke the anchors for the roll pins on mining machinery which were supposed to prevent the pins from spinning(because they were installed with turbine oil).
no need to remove the zerks as it would be one more place for dirt to collect etc.
/ How does this bearing work??? #8
Freezing the bearing in dry ice for 30-45 minutes works a whole lot better than your freezer.
/ How does this bearing work??? #9
The original equipment bearings that came on the disk harrow were open, with an inner race that extended substantially beyond the sides of the outer race. Separate grease/oil seals were installed in each side of the housing after the bearing was pressed in. These seals fit around the extended inner race, so the bearing was in a chamber that was in theory sealed from dirt, and grease was pumped into the grease zerk and flowed to the bearing via a groove machined into the bore of the housing. The seals were installed with the lip to the outside and were designed so that grease could (and should) be pumped into the housing until it flowed out through the seals. This did not damage the seals because the grease was not pumped against the direction of seal. Pumping the grease until it flowed removed (or was supposed to remove) any contaminants that sneaked in past the seals. Ag universal joint seals are designed this way and that is why they should be greased until the grease flows past the seals.
/ How does this bearing work??? #10
Where does someone go to get dry ice?
I've always wanted to have access to it, but didn't really know where to look to purchase some.
Stuff would be great at a Holloween party.:D :D
Wedge
/ How does this bearing work??? #12
Many grocery stores have it nowdays...look for chest freezers in their frozen food sections...
/ How does this bearing work??? #13
large sockets make great bearing drivers. ditto on the sealed bearings not needing grease.
soundguy
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2006 Ford F-150 Ext Cab Pickup Truck (A61573)
2006 Ford F-150...
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
1995 Landoll Trailer, VIN # 1LH17AUHXS1007250 (A65563)
1995 Landoll...
