How hard should bearing buddies be to install?
   / How hard should bearing buddies be to install? #11
The ones I use have a small releif hole when you put the grease in the spring platee comes out and uncovers the hole and grease comes out. You need to check them several times the first few hundred miles until the hub is full. I pull trailers 90 % of the time and have never had a bearing go bad in 35 years I just check the bb on a regular basis.
   / How hard should bearing buddies be to install? #12
I have a set like that on my car haul trailer. Once again, rocking the pressure plate will tell you if it needs grease. The reason the hole is there is to prevent over pressurizing the BB and blowing out the rear seal when servicing.
Chris
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2010 FORD F-150 (A58214)
2010 FORD F-150...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2013 Ford F-250 Super Duty Service Truck, VIN: 1FT7X2BT7DEB91437, Extended Cab, 4x4, 6.7 L Power (A59076)
2013 Ford F-250...
