How hard should bearing buddies be to install?
   / How hard should bearing buddies be to install? #11
The ones I use have a small releif hole when you put the grease in the spring platee comes out and uncovers the hole and grease comes out. You need to check them several times the first few hundred miles until the hub is full. I pull trailers 90 % of the time and have never had a bearing go bad in 35 years I just check the bb on a regular basis.
   / How hard should bearing buddies be to install? #12
I have a set like that on my car haul trailer. Once again, rocking the pressure plate will tell you if it needs grease. The reason the hole is there is to prevent over pressurizing the BB and blowing out the rear seal when servicing.
Chris
2011 Big Tex 18' Trailer, VIN: 16VCX182XB2E04765, Tandem Axle, GVWR: 7,000 Lbs., Asset# 25 (A59076)
2011 Big Tex 18'...
Rolling Steel Hoist w/Chainfall, 9' W x 12'H (A59076)
Rolling Steel...
More info coming soon! (A56859)
More info coming...
JOHN DEERE 624K WHEEL LOADER (A58216)
JOHN DEERE 624K...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
2008 FORD F-350 XL SUPER DUTY CREW CAB TRUCK (A58375)
2008 FORD F-350 XL...
