I guess I have to agree with Patrick on this one. I am in the decision process on a tractor too. I have tried to list the chores that I need/ want to do, and then decide on the implements that I need to accomplish those tasks. Once the implements are chosen, I can easily see what size tractor / mower I need, how much it should weigh, etc. If I have many chores that require a heavy tractor with lots of pto hp, then I probably should really consider having a separate mower. Heavier tractors can certainly be used on sensitive areas, but tire choice becomes more critical to spread that weight out. Look at the equipment that is used on golf courses for example. I have 13 acres, but mow about the same amount as the OP. The land I mow is hilly, and rough in areas. After using both riding mowers, and a
BX22 ( not for mowing) on my particular land (tends to be wet in areas, clay in areas, etc.) I have decided that I don't want to use anything heavier than the JD 2000 series, or larger Kubota "B" series for much mowing, and the smaller tractors of both brands are to be preferred for that task as being the limit. My Simplicity Legacy, at around 1000 lbs has proven to be a good size for traction, stability, and yet low impact. Still there are areas that I have to use the same track, and over all my years of use, one can still see depressions that match the tractor tire width. To answer the OP question, I think 1000 lbs to 1800 lbs would be best for mowing, especially in sensitive areas. Larger is Ok, but look closely at tire choices.
My
BX22 gave me a good look at the weight thing, and in some ways was an actual worse case scenerio. Though the tires are as wide (12") as many larger tractors they are much smaller in diameter, so the footprint is smaller. With my rear tires loaded, and me aboard the thing weighed close to 3000 lbs with backhoe, and loader mounted. Imprint in sensitive areas (bar tires) was much more noticable than my Simplicity...... same day, same conditions. With the backhoe off, but the loader mounted, the results were the same. With the backhoe, and loader off it did more damage than the Simplicity but wasn't too bad except where it was really soft. With me on board, it probably weighed in the neighborhood of 1800+ lbs that way. Larger tires would have made that even better.
