How important are tire chains on a 4WD for snowblowing?
   / How important are tire chains on a 4WD for snowblowing? #11
Both of my machines (b7500 & b3030) had the kubota front snowblower set up. Both machines had turf tires, no need for chains IMHO.
   / How important are tire chains on a 4WD for snowblowing? #12
I have a set of chains for my B2910 with turf tires. I have a 6'6" snow blade for pushing snow. Have never used the chains in 6 winters.
   / How important are tire chains on a 4WD for snowblowing? #13
I live on top of a mountian on the Md/Wv line and we do get alot of snow. I have tire chains on my Case backhoe but it is only 2wd. I also have a Ber-Vac 64" blower on my Yanmar 2000bd. It is 4wd and I have never had a problem snowblowing my 2.5 mile driveway/road to the blacktop road down the mountian that the county plows. I would say you would be fine without the chains.
BTW, if you have never used a rear mount blower on a gravel drive, be careful where you point the chute. gravel tends to shoot out of it like a machine gun if you get too close to the surface. Not too good on your car windows !!!! Been there and done that , don't ask.
Thanks for the warning. I'm going to get skid shoes and I'll be sure to leave a reasonable clearance. I expect that I will pack down a layer of snow for the first few snowfalls instead of blowing it to the gravel.
Sounds like I'm going to be better of spending the $$ on loading tires. Should help with day to day stability mowing et. al. in addition to providing a bit more weight for traction on the snow.
   / How important are tire chains on a 4WD for snowblowing? #15
Loading tires is a good way to spend your money. It gives several advantages when there is no snow on the ground, specifically more balast and stability.
However, loaded tires are no help if you let your driveway turn to ice. If that happens then chains are a must.
   / How important are tire chains on a 4WD for snowblowing? #16
As others have said, turf tires are better on the snow and ice that R4s. My JD4100 with turfs works great on the ice with no chains (in four wheel drive). My driveway turns to ice after I leave the "pack" for a few blowings, and there is quite a bit of slope. I did buy rear tire chains and used them when I moved snow with the loader, but now that I blow the snow instead, the push force required is much less so I have not put them on for two years.
BTW, for a better price on chains, find a place that sells Peerless chain for trucks, and order the coorect size for you tractor tires (back wheels only is enough). The chains are a smaller gauge than tractor chain, cause they are expecting them to be used on a highway vehicle, but its all you need.
Chains on turfs is ultimate, since the tire is flat the chain is forced to be exposed nicely everywhere. Chains on an ag tire ( and maybe an R4) are only half exposed to the work.
I evenutally decided to bite the bullet and order the chains with my blower.
My implement dealer is sourcing both from the same supplier and was able to give me a really good deal on the chains as a result. Figured I might as well do it while he was going out of his way to get a me a good deal.
Thanks for all the replies.
   / How important are tire chains on a 4WD for snowblowing? #18
I got chains last year before I had loaded tires. Living just around the corner from you and using the same machine as you have, I can not say enough how pleased I was with the increased traction. I got quite a heavy set used for 100$ (from a Massey 35) and had to cut a few sections off. If you do any bush work at all, I think you won't be happy with unloaded and unchained tires. On the R4's the chains ride up on the treads -- don't get lost in the treads like the ladder chains tend to on R1's. Chains are supposed to be hard on old pavement...haven't noticed much trouble yet. Shawn
   / How important are tire chains on a 4WD for snowblowing? #19
A good bit of Ontario is fairly flat. If your driveway isn't on a hill, you should be okay without chains unless you get ice. For ice or sleet, you'll need chains.
I've had no problem without chains with turf tires on my 4wd 4010, but my driveway is relatively flat, and we haven't had that much snow in the last 2 winters.
Before, I had a Gravely that I used either with dual (4) tires (turfs about 3 winters and then got a set of ags and put screws in the treads) with a 48" snow plow or single turfs with chains for the snow blower. Didn't have much opportunity to test out the Gravely with dual Ags with screws into the outer part of the lugs because I got the 4010 about that time. The Gravely would push the snow plow without chains fairly well using dual turfs. Definitely needed the chains for pushing the snow blower because it was a heavy mother! Only used the snow blower one time when we had about 7" of sleet. The plow wouldn't touch it.
You might want to try putting some metal screws into the outer part of your R4 lugs. Just measure the depth of the lugs and buy screws the right length. If you do a searth on the forums, you'll find experience folks have had with using lugs in motorcycle racing on ice.
Ralph
   / How important are tire chains on a 4WD for snowblowing? #20
"I used the spreader one time but found it easier to just use the bucket and gentle touch. That way theres no switch between the rear blade and the speader."
I have a spreader that is designed to mount on the rear of a car/truck w. a 2" receiver ...I have a clamp on receiver for my bucket and so can blow w. the rear mounted blower and sand w. the bucket mounted spreader ...works well, no changeover.
2011 Land Rover Range Rover Sport AWD SUV (A51694)
2011 Land Rover...
2016 MITSUBISHI OUTLANDER SPORT (A52472)
2016 MITSUBISHI...
JLG 1255 Telehandler (A52748)
JLG 1255...
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
