How long should a Weil McClain boiler last?
   / How long should a Weil McClain boiler last?
Thanks for all that great info AK.
   / How long should a Weil McClain boiler last? #12
While we are on the subject of boilers I have an Axeman Anderson that might be close to 30 years old, that I will need to replace this summer, if it lasts that long. My plumber wants to install a Utica Boiler, any good? My Axeman Anderson is steel and the Utica is cast iron. What are your thoughts on cast compared to steel?
   / How long should a Weil McClain boiler last? #13
Where are you located? If you are near me (Rochester, NY area), I can recommend someone who will do the job right the first time.
Aaron Z
I'm in NJ.
A colleague at work has a subscription to Angie's List. If it comes to a replacement, I think I'll give that a try.
I'm reconsidering the idea that my pump is bad.
The boiler hasn't turned on by itself now for a day.
When I hit the reset switch, it runs for a few minutes and then shuts down before the water temp is up to the high range. If I wait a few seconds, another reset will turn the boiler on again and it will run for a few minutes then shut down.
It doesn't seem to stay running on its own until it reaches the high water temp range as I would expect if the problem was with the pump.
My sense of it is that if the problem was with the pump, the water temp would get to the high range before the boiler shut down and that after it cooled it would cycle on its own....but that's not what's happening.
This condition that I'm describing has gotten worse over the course of the past few weeks. A few days ago the boiler had been running normally for hours at a time and within the past day or so it seems it only runs for a few minutes when I hit the reset button.
I'm going to try to clean the controller switch. (the box with the reset button) to see if that makes a difference.
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
Portable Restroom (A54865)
Portable Restroom...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2004 FREIGHTLINER FL70 FLATBED W/TANK & DITCH WITCH MIXER (A55745)
2004 FREIGHTLINER...
