AndyMA
Elite Member
- Joined
- Oct 11, 2000
- Messages
- 3,714
- Location
- Windham County, Conn
- Tractor
- Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Chuck_Lind said:Have an engine block heater installed. Just for fun last winter when it was around 10 degrees, I tried starting my TN65 without the aid of the block heater. Forget it...wouldn't even turn over. Then...I plugged in the block heater and let it on for about an hour. It started like it was summertime. I did let it run with the clutch engaged for about 10 minutes; then slowly operated the hydraulics. Worked just fine.
Then engine block heater is a great investment if you're going to use the tractor during the cold weather.
Interesting, My TN75D and the TN75S before it didn't have block heaters. Never had the slightest problem starting. Until about 10 degrees I don't even use the ThermoAssist (which warms the fuel). I would say it starts on what seems liek the first revolution. Like immediately. My 2120 has never had a problem starting without block heater in it's 20 years even with 2 feet of snow on it. Below about 30 degrees I will use the glow plugs for about 15 seconds and crank up the throttle to start. As far as warming up, at least a few minutes until the hydraulics work close to normally.
Andy
