How long to clear a flooded chainsaw?
   / How long to clear a flooded chainsaw? #1
PhilNH5
Platinum Member
SE NH
Kubota B3000HSDCC
Last night I went to cut some firewood. It rained all weekend so I was antsy to get back on schedule. Between suiting up in safety gear and collecting the saw, wedges. files, etc and just plain being excited to be getting some work done I flooded the chainsaw.
It is a Stihl 025C and I am sure I pushed the primer bulb twice the recommended amount. I could smell the gas as I pulled the cord. Okay it is obviously flooded. Put the saw down and force myself to take a 10 minute break. Didn't work so in 5 minutes I am trying again - minus the priming. Still no luck. So I force myself to take another 10 minute break (from what? - I haven't done any work yet.) Still no start. Utter a few choice words and put everything away. Started raining anyway.
Go back out 2 hours later to test - no go. Go out first thing this morning and the saw started right up.
So how long should it take. Is the diaphragm carb in a chainsaw the reason it takes so long to "dry out" or is it because the 2 cycle mix slows it down?
Phil
   / How long to clear a flooded chainsaw? #2
There is nothing like tiring yourself out trying to get a tool started.. usually my Stihl will start right up.. when it doesn't.. a dirty air filter needed cleaning. This Stihl was my father's and has seen it's fair share of work.. I just hit it w/ startup spray.. and avoid tiring myself out before I even get started.
If you want to dry-up the carb faster.. removing the air filter should help.
   / How long to clear a flooded chainsaw? #3
Phil,
Typically what I've done in the past is to take the plug out, dry pull the starter a few times to dry the cylinder out and put the plug back in and give it a try with no choke. Too much fuel won't allow the spark to ignite if it has no oxygen in it.
   / How long to clear a flooded chainsaw? #4
another thing you can do if you are really really careful is to take the plug out and while pulling the starter cord slowly with one hand light a lighter and hold it behind the hole the sparkplug screws into, it will burn the excess gas out of the cylinder
   / How long to clear a flooded chainsaw? #5
I treat the 2-stroke saw like my big bore 4 stroke dirt bikes. When I tip them over, don't ask, they flood out. I open the throttle fully and spin the engine ten kicks and then then I give it a try.
On any engine that I believe is flooded, I do not sit around waiting for fuel to evaporate. I purge the cylinder with as lean a mixture as I can produce. No choke and full throttle.
   / How long to clear a flooded chainsaw? #6
</font><font color="blue" class="small">( I purge the cylinder with as lean a mixture as I can produce. No choke and full throttle. )</font>
How does full throttle produce a lean mixture? I would expect a lean mixture to come from no throttle and no choke.
   / How long to clear a flooded chainsaw? #7
<font color="blue">How does full throttle produce a lean mixture? I would expect a lean mixture to come from no throttle and no choke. </font>
The throttle meters fuel/air mixture - full throttle is "open" - ie maximum fuel/air available - idle is "closed" - least amount of fuel/air available.
The venturi effect draws different amounts of fuel depending on vaccum - higher engine speed = more vacuum = more fuel.
When starting you have max available air, but the engine isn't spinning fast (starting from 0) - so you aren't drawing as much fuel = lean mixture. This is why there is a "choke" - to cut off the air intake making for a richer, eaiser to combust mixture.
Therefore - the leanest condition for starting is full throttle, no choke.
Wow - actually putting my Internal Combustion engines class to practical use... /forums/images/graemlins/cool.gif /forums/images/graemlins/tongue.gif
   / How long to clear a flooded chainsaw? #8
I couldn't have said it better myself. A dead or slowly spinning engine isn't sucking hard enough to pull fuel out of the carburetor while the throttle blade is wide open. This will purge the engine rapidly.
Cars have an accelerator pump in the carburetor that squirt fuel in with each application of throttle. So don't go pumping the pedal on a car/truck with a flooded engine. Put the hammer down and leave it down while clearing the flooded engine.
When you have the choke applied to a bike or saw engine and you give it full throttle, you are getting maximum fuel delivery since the air supply is cut off but the fuel supply is wide open. You will flood the saw quickly but on a big bike, this step precharges the cylinder with a good mess of fresh fuel to help keep it running long enough to get a good flow of mixed fuel and air out of the carburetor.
You learn a lot about carburetor function when riding a big bore, kick started, four stroke motorcycle and crashing it every now and then.
   / How long to clear a flooded chainsaw? #9
Maybe so, but factory made cars haven't come with carbs in 20 years or so.................
   / How long to clear a flooded chainsaw? #10
That's OK, I've only been alive for 20 years or so.
Wow, Thanks for the replies and insights.
Hazmat thanks for the detailed explanation. I had assumed something like that was taking place. On the Stihl 025C the start and choke are on the same lever. You set it to full throttle and choke until the engine turns over. Then you slide the lever to the full throttle/no choke position and pull until it starts. Unfortunately I had flooded it before I ever pulled the rope. So I was trying to clear it. No amount of fullthrottle/nochoke would start it.
I think ByronBob's idea of pulling the plug would be worth a try if I get stuck again. I will definitely pass up on Madmans idea of clearing out the gas with a lighter. I value my saw and eyebrows to much to do that /forums/images/graemlins/smile.gif
Phil
   / How long to clear a flooded chainsaw? #12
Do Harley's still have carbs? I thought pretty much everything had gone to FI by now.
   / How long to clear a flooded chainsaw? #13
Yes, harleys are still available with carbs. However, they are also available with fuel injection. The vast majority of motorcycles, even the super high tech crotch rockets and modern 4 stroke dirt bikes still use carburetors. We offroaders still dunk our bikes in the water on occasion .
The crotch rockets are mostly 4 cylinder engines with a neat row of four individual carburetors, one for each cylinder.
The biggest recent innovation on off road fuel systems is the application of accelerator pumps to allow you to snap the throttle without bogging the engine.
   / How long to clear a flooded chainsaw? #14
</font><font color="blue" class="small">( The biggest recent innovation on off road fuel systems is the application of accelerator pumps to allow you to snap the throttle without bogging the engine. )</font>
I assume you're still talking about motorcycles? Cause accelerator pumps have been on car carbs since at least the 40's........
I know a lot of boat engines, particularly outboards have gone to FI too.
   / How long to clear a flooded chainsaw? #15
Yes sir, the fastest single cylinder off-road motorcycles have just within the last few years started using accelerator pumps on the carburetors. Also, they have equipped some of the carbs with throttle position sensors to provide information to the ignition system.
My 2001 Honda XR400 still uses a carb with no accelerator pump or TPS. At least it has electronic ignition. You have to learn the starting procedure for various situations or you will wear your leg out in no time.
An american company named Cannondale tried fuel injection on the off-road bikes and the company has since tanked for various reasons including high initial cost.
2020 DY TP90 TRAILER MOUNTER CONCRETE PUMP (A59905)
2020 DY TP90...
Towable Centrifugal Water Pump (A59228)
Towable...
2010 Deere 318D (A60462)
2010 Deere 318D...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
