How many hours on your Yanmar?
   / How many hours on your Yanmar? #21
i even tried the piece of card trick and never saw or had any oil on it. i can take the oil cap off it and feel nothing, very happy with this little machine.
If i take my oil cap off there is mist blowing all around, i guess i got blowback? I think though its more from the crank rotating around in there though.
   / How many hours on your Yanmar? #22
Yeap! If your getting blow by it's a pressure build up in the Eng. Block. Causes of Blowby for example " compressed pressure getting by the Piston Rings,Valves, Head Gasket, Crack in the Block/Head etc. escaping into the block and building up pressure causing Oil to get Blown Out. That is what this Vent tube is for is to prevent any or pressure to build up in the Eng. or Block. If you do Have "Blowby" it will most likely show coming out the tube. Steam, Condensation, Water,Anti Freeze or OIL. Thats what it's there for to let pressure out that will somewhat build up naturally by moving parts etc. Nothing comes out of mine :thumbsup:
And back to the Orig. post. I bought my Ym2000 with 280Hrs on the Clock. I Now Have 399.4 I put on it in 3yrs.
Alright Here's what I come up with. I put Basicly the same amount of use on it that it was designed for. For me it's used with my FM. and Tiller for my Mothers SMALL Garden. Basicly around 40 hrs. a Yr. Give or take. Do the Math. 40hrs.x 30yrs.=1200Hrs. Put or Add 280Hrs. of whats showing on the Clock and or the 1000 role over or not showing. And it's about dead on the money 1480. Compare it to whats showing 1399 :cool:
Said good bye to my yanny today. It made its way south about 3 hours to it's new home. :)
   / How many hours on your Yanmar? #24
Shame on you!:mad: Just joking!
So have you got enough saved for that skid yet?:D
I am looking at one. :D I will keep y'all updated with the required pictures for proof. :thumbsup:
I felt the same way for an hour after it left but now i am looking on to the upgrade and it will all be worth it. :thumbsup:
2015 Kenworth T880 QMC 8060R 50 Ton Tri Axle Crane Truck (A60460)
2015 Kenworth T880...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
CAT Chassis Only (A59076)
CAT Chassis Only...
Zero Turn Mower (A59231)
Zero Turn Mower...
2012 International Prostar (A56438)
2012 International...
