How many implements/ attachments do you own?
   / How many implements/ attachments do you own?
drawbar counts?
Why not, it hooks on the 3PH and you can pull stuff with it.
The new total is 486 implements/ attachment from 37 people with a average of 13.13
   / How many implements/ attachments do you own? #72
Darn, I'm below average...better get on craigslist :laughing:
   / How many implements/ attachments do you own? #73
Hi all,
My wife thinks that I am a tool and implement addict, but I just like to be prepared.
From front to back we have:
Front: FEL w/bucket, 1 pair of chain-on forks, bucket spade.
Middle: 60" MMM.
Rear/3-point hitch: HF QH, Ballast box @ 675# with PVC tool carriers, trailer hitch box, and chainsaw carrier, 48' Gannon Earthcavator R/O BB w/ trailer hitch box, 2 x carry-all/pallet forks, boom pole, 48" concrete-filled lawn/yard roller, and a drawbar.
I count 12 in all.
I am looking for a "York"-type rake and a "Bush hog"-type mower and planning to weld up a landplane (when I get my knee back and my garage floor in) from the metal collected/rescued from the dumpster at work.
Good topic and collective responses, so I offer thanks to the OP and all the rest of youse!
Thomas
   / How many implements/ attachments do you own? #74
My name is Dave and I'm an Implementholic. It's gotten so bad I no longer post pictures of everything I purchase. I just silently add them to my signature and hope no one will notice. Last Wednesday I went to the dealer to purchase a tube of grease and saw they had in a new shipment of pallet forks. I didn't have pallet forks so I bought them. I'll come clean, here's the picture:
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=335823"/>
Friday rolls around and the pallet forks are great but they are no grapple. Talked with the guys at WR Long and ordered an 84" wide with 70" opening dual lid model through my dealer. Should be here in three weeks.
Yesterday, I get a call from same dealer saying my HLA 3000 plow is in. (Pictures in the snow section already)
It's a sickness and most of you could be classified as enablers.
I need help!
Until that help arrives I going to search for snow blowers on a different thread. Or maybe tooth bars.....
I can certainly help you. I can stop by with my trailer and you can load it up and get rid of everything. Trust me, you will feel much better afterwards.
Haha. Seriously, no one can have too many implements.
   / How many implements/ attachments do you own? #75
I have two tractors each with a FEL with SSQA buckets, so does that count as 2? Having two tractors at two different locations means I have doubled up on a couple of attachments. Two SSQA pallet forks, two 7' back blades and two 3 point tow bars. The L39 has a backhoe with two quick attach buckets. Other three point implements that I only have one each of: BX62 chipper, 6' box blade, 6' snow blower, 7' landscape rake, log splitter, rotary mower, disc, two bottom plow, boom pole and two homemade drags.
I actually have a third tractor, a Wheel Horse D250. I don't use it much anymore so I almost forgot about it. For it I have a rototiller, MMM 60" mower, front hydraulic lift and angle 60" blade, homemade front carry all that uses the front blade cylinders for lift and dump, snow blower and homemade 400 lb rear counter weight. I had only been using it for snow removal. When I got the 3 point blower for the larger tractor, I told my wife I would sell the D250. But somehow I keep finding uses for it thereby delaying the need to sell it :D, most recently the rototiller.
   / How many implements/ attachments do you own? #76
Two tillers48+60", two box blades 48 72", back blade, cultivator, harrow, screen drag, two carryalls, backhoe, shop made land plane that doesn't work very well. Also two loaders and one set of forks. 12 if you don't count the buckets 48&54",the mowers or quick hitchs
   / How many implements/ attachments do you own? #77
For the Oliver 77 I have a Meyer ST84 front snowplow & a JD #5 sickle bar mower. For the Kubota B3030HSDCC I have the LA403 front end loader, the 72" mid mount mower, 5ft King Kutter rotary cutter (pull type), 6ft. front snow blade, ballast box, 6ft. landscape rake, middle buster, sub-soiler, 5ft. rototiller, single row cultivator, PTO generator, fertilizer spreader, and an old trailer that is no longer road-worthy. 15 if I counted correctly.
   / How many implements/ attachments do you own? #78
For my Kubota Grand L3540HST I have the following FEL attachments: heavy duty rounded bucket, custom pallet forks, custom tree scoop and Meyer snow plow conversion. For the 3pt, I have the following: 7' box blade, 6' gill rake, 6' finish mower. The mower is on most of the summer and the box blade is on most of the winter when I'm plowing.
On my wish list is a 6' tiller.
   / How many implements/ attachments do you own? #79
Two words. King latter. Inexpensive and effective.
   / How many implements/ attachments do you own? #80
I feel so inadequate. :ashamed:
FEL: QA bucket and forks
3-PT: Boxblade, PHD, subsoiler, middle-buster
2 - WEATHER GUARD TOOLBOXES (A55745)
2 - WEATHER GUARD...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2018 CATERPILLAR 326FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2018 HINO SA (A58214)
